motor warming
08.05.2020 16:26 # 1
iso
First of all, I have introduced myself, I am kosovaliy ... I wanted to ask you a question. I have a 2002 206 1.6 16v vehicle .... the engine temperature is over 90, but this is not always happening ... sometimes it is becoming more frequent .... I checked the engine oil, I checked everything okay what do you think can be a problem ... by the way, there is no letter I in the tsater
08.05.2020 16:26 # 2
enilder
Could the problem be overheating?
08.05.2020 16:26 # 3
yavuz25
What is the status of your thermostat?
08.05.2020 16:26 # 4
MagicPerformance
no problem, sometimes I get up to 100.
08.05.2020 16:26 # 5
ose
I do not have a problem, but let me rest assured, if you say that the water circulation is not done, have the thermostat checked. The control of the thermostat is simpler.
08.05.2020 16:26 # 6
Ucyuzalti
Normal operating temperature 90 satin & nbsp; "LOL" 90 - 100 normal & nbsp; "Wink"
08.05.2020 16:26 # 7
MagicPerformance
If there is a problem but you need to be comfortable, check the water level of the vehicle at regular intervals. It will not significantly reduce.
08.05.2020 16:26 # 8
Ucyuzalti
Friends, if you are afraid that the vehicle will move, the event is very simple, now I have an 87 thermostat on my vehicle.
08.05.2020 16:26 # 9
zerzevat
The general problem of the first areas of peuteotes :) will be the subject, but I said let me write to someone that maybe it will be useful.
opens 90 fans in other brands. the indicator stops at 90 .. but pejos aren't. It opens to 100. 98 I think ... if the indicator exceeds 90 ....
If
also exceeds 100, there is a problem. DO NOT STOP THE VEHICLE immediately bring the heater to the warmest position. turn the fan on completely. and also operate the air conditioner. Stop the heat when the temperature is below 90 and have a specialist look.
08.05.2020 16:26 # 10
zerzevat
of course the vehicle is idling. open the engine cover and stay away from the engine (sometimes the hose may burst - do not boil)
If
still continues to rise, sotop.
< div> YOU MAY ALSO GAVE SLOWLY SLOW WATER ON THE RADIATOR. YOU CAN SPREAD WATER FROM THE FRONT GRILL ...
I say RADIATOR !! DO NOT REMOVE TO THE ENGINE. BLOCK ROOFS. THE ENGINE WILL RUBBISH!
