MOTOR VIBRATION
08.05.2020 18:27 # 1
ikurklu
Friends,
My car is 1999 model 206 automatic gear 1.4 XR 137000 km.
Another problem came up, when my car started for the first time, it was trembling at idle, what do you think is the reason?
08.05.2020 18:27 # 2
ErdiCoskun
Engine chock or one of the ears may be broken, right or left or something, the throat butterfly is dirty, does not vibrate at idle, makes fluctuation in speed, I do not know if the vehicle is spinning at idle, check the spark plugs if the vehicle is gasoline, if there are shaking or something, these are the ones that come to my mind.
08.05.2020 18:27 # 3
ikurklu
Thanks,
I will take it to the service or industry as soon as possible again. :(
How much will this transaction cost you estimate?
08.05.2020 18:27 # 4
kuscu38
[QUOTE = ikurklu] Friends,
MY CAR 1999 model 206 AUTOMATIC GEAR 1.4 XR at 137000 km.
Another Problem MORE turned out, Added the idle when my CAR type is running makes too much tremor, what do you think is the reason?
vehicle lpg limi?
08.05.2020 18:27 # 5
suppor
Could there be Kayistan?
Are you sure the sound of chills comes from the motor?
08.05.2020 18:27 # 6
ikurklu
My car's 1.4 petrol automatic transmission, it sounded like it came from the engine when I was inside the car, but I'm not sure.
08.05.2020 18:27 # 7
kuscu38
I agree with my friend if the vehicle is gasoline, chock or have a check on the ears ...
08.05.2020 18:27 # 8
CrimsonChild
I have the same problem, my guess is as follows.
While the vehicle is at idle, it goes up to 1.000 rpm and descends back and makes it stand still, not tremendously.
08.05.2020 18:27 # 9
ahmed206
[QUOTE = CrimsonChild] I have the same problem, my guess is as follows.
[/ QUOTE] If this is the case, I have it too.
I have a service software on my hand and it says something about the tremors that are cold.
1- Check grounds
2- Water is leaking from the windshield water jet. Change the jet and clean the 4th injector.
08.05.2020 18:27 # 10
ikurklu
Friends,
By day I went to a peugeot service in the industry.
He said that he could be from the throat butterfly for idle shaking and he ripped it out and cleaned it again, it seemed that there was no flickering when we started it, and he said that if the engine continues to be checked again when the cold continues, it may be a problem in the coils or elsewhere. I gave 50 TL for this job. On the way back from the service, I was standing in the lights and started shaking again at idle. I stopped it and started it again, it worked again, trembling, so it wasn't from the throat butterfly.
I don't know what to do now. I say if I take it to the authorized service? the ikurkl 2014-04-23 19:18:39
08.05.2020 18:27 # 11
ErdiCoskun
You gave a lot of money to the throat butterfly cleaning, also, after cleaning, it has to connect to the computer and adapt, did it?
08.05.2020 18:27 # 12
ahmed206
Calibration.
