Motor master recommendation in Konya
08.05.2020 19:45 # 1
Kemal106
I want to show a master who has a problem with oil in my vehicle. A master I showed wanted 750 TL for the upper lid gasket and the eccentric caps. Is this price really normal
08.05.2020 19:45 # 2
usta307
My brother, konya karatay industry, there is efe peugeot or baki peugeot special service i go to baki master, you can go to both of the friends who go to the master.
08.05.2020 19:45 # 3
Kemal106
Thanks
08.05.2020 19:45 # 4
Kemal106
Does anyone have information for the process I mentioned above. Are these prices really
08.05.2020 19:45 # 5
around roughly around, my teacher will say 30 rubles antifreeze + gasket set max 100 rubles amount break set + 150-200 closer + motor oil 60-80 rubles + air filter 10-15 rubles + pollen 15-20 rubles + oil filter 15-20 tl + spark plug 20 tl + recirculation change around 80 tl + workmanship 200-250 tl we say something like a total of 700-800 tl is normal I think you can also get a list from the master, you can compare what will change.
08.05.2020 19:45 # 6
Kemal106
Revolution nozzle gasket eccentric lap top cover gasket oil and oil filter. They didn't mention the stuff because they didn't do it
08.05.2020 19:45 # 7
[QUOTE = Kemal106] Peel-off nozzle gasket eccentric lap top cover gasket oil and oil filter. They didn't mention the stuff because it was not overheated [/ QUOTE]
valla kemal i last summer timing + recirculation + topcap grinding and gasket replacement + exhaust gaskets + oil + air + pollen + antifreeze + spark plug + v belt + spare water tank cap had kept a few minor maintenance 1000 tl.
