Motor master recommendation in Ankara (oil reduction)
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508
08.05.2020 21:14 # 1
ibra
Hi friends.
The 2011 model 508 1.6 THP gasoline vehicle I bought last year at 82,000 km has been reducing oil since I bought it. At first it was around 1,5 lt at 2500km. However, now it has reached around 1-1.5 lt at 1000km.
There is no leakage of oil from the vehicle.
Since I reside in a provincial district of Kütahya, there is no place or time to show the vehicle. I will go to Ankara for 1 week in the coming weeks. Would you recommend a good master there to look at the engine?
08.05.2020 21:14 # 2
pusutr
Hello there. My cousin is working in private peugeot service. Şaşmaz auto industry site 2559 sk. no: 42 -erhan peugeot service. If you go there is Doğukan. your uncle tevfik guided me.
08.05.2020 21:14 # 3
First of all, welcome to us. If you want ivedik mas peugeot, you can meet here.
08.05.2020 21:14 # 4
umydn
Hello, welcome to us.
You can go to the place recommended by our Soner friend or Tekved Peugeot in İvedik. I went to Tekin Peugeot and was very satisfied. Here I am doing a job that I can handle 500 tlye elsewhere, 400-450 tlye and they work as if they are applying to their own cars. I will make a sampling. My car's Stop light and malfunction lamp were on. Because I could not go to Ivedik because I worked, the Scythians also visited several places, saying various kinds of failures and saying herpes. Finally, I found a suitable time and went to Ivedik. He connected it to the PC, looked at the malfunction code and deleted it. They said that there would be no problems. They did not charge a fee and 1 and a half months passed, I drive my car without any problem.
08.05.2020 21:14 # 5
ismailkaya
Possible turbo gives oil to the engine. Does your vehicle occasionally blow heavy white smoke at high revs? If heavy smoke is blowing, it will also damage the engine piston valve etc. Melt. your expense increases. Look at the turbo first.
08.05.2020 21:14 # 6
ibra
[QUOTE = ismailkaya] Possible turbo gives oil to the engine. Does your vehicle occasionally blow heavy white smoke at high revs? If heavy smoke is blowing, it will also damage the engine piston valve etc. Melt. your expense increases. Have a look at the turbo first. [/ QUOTE]
No dense white smoke phenomenon. No water reduction.
08.05.2020 21:14 # 7
Then, I would like to test your teacher for a compensation test.
