Motor Fan Malfunction
08.05.2020 20:32 # 1
gogly35
Hello friends,
I have a 2009 model LPG 308. I have a serious fan problem for about 6-7 months in my vehicle. The fan is running at the first start (when the engine is cold) or sometimes while driving in traffic, but the temperature is normal.
For this problem, we first took it to the special masters, the problem was not solved, then we took it to the authorized peugeot service in Izmir, for days, they worked with the car, the oil changed, the software was updated, the engine was recirculated with liquid, the spark plugs injectors were changed. but we still have the same problem, I can't get out of the job anymore. In the private master, the authorized service could not solve this problem.
Moreover, when the vehicle stopped for about 8-10 hours and started for the first time in the morning, the engine runs so irregularly that the sound is like a helicopter propeller. I used the car for a long time in both gas and gas.
Please, I would be very happy if you helped I had a hard time ..
08.05.2020 20:32 # 2
talip206
You have to find a good electrician somewhere, like a bowl or a brain malfunction. If there was no private and authorized service, it is difficult for us to make a prediction here. The problem may even be due to incorrect installation of the lpg system.
08.05.2020 20:32 # 3
gogly35
I suspect the fan electrical failure, but it is in the form of giving the symptom of the engine failure from the service. It is a last resort.
08.05.2020 20:32 # 4
ismailkaya
What did you do to this vehicle 6-7 months ago, did you change the battery or did you have an accident or you hit the bottom of the vehicle somewhere while you stopped and started to experience this problem. If the ignition system does not ignite the ignition system, the vehicle runs eruptively, the exhaust will explode when the gas is rooted. Does the vehicle occasionally crash while on the road? Either there is cable contact or ignition system, it seems to me from the coil and spark plug.
08.05.2020 20:32 # 5
gogly35
[QUOTE = ismailkaya] 6-7 months ago, you changed the battery of what you did or did you have an accident or you hit the bottom of the vehicle somewhere, you started to experience this problem. If the ignition system does not ignite the ignition system, the vehicle runs eruptively, the exhaust will explode when the gas is rooted. Does the vehicle occasionally crash while on the road? There is cable contact or ignition system, it seems to me from the coil and spark plug. [/ QUOTE]
Hello, November of the vehicle, I think the battery has changed, the injector plugs of the bob have changed, the malfunction has not been solved. the car does not react to the accelerator, the cycle takes a hard time, then I stop the engine and wait for 10 seconds, it starts to improve.
I am very bored to this situation now .. I am thinking of upgrading my vehicle, but I cannot sell it with these problems ..
08.05.2020 20:32 # 6
talip206
The electrical cables of the LPG system are drawn from the cables that go to the coil, which is 90 percent. It is necessary to remove and check those cables backwards. It is necessary to look for contactlessness or if there is a burning oxidized cable. In the faults related to the coil, the malfunction of the cold engine becomes more evident and it manifests less when the engine gets hot.
08.05.2020 20:32 # 7
gogly35
[QUOTE = talip206] The electrical cables of the lpg system are pulled from the cables going to the coil, which is 90 percent. It is necessary to remove and check those cables backwards. It is necessary to look for contactlessness or if there is a burning oxidized cable. In the faults related to the coil, the malfunction of the cold engine becomes more evident and it manifests less when the engine gets hot. [/ QUOTE]
tomorrow, let me examine all the cables in detail and identify the places that wear out. Thanks for your advice.
08.05.2020 20:32 # 8
Orcun.Dmr
Have you checked the spark plug cables, sir? If there is a rupture in one of the cables, it will touch the motor, the chassis will be made and the coil will burn. You should have a check. 307 1.4 hdi 2017-09-03 00:13:11
08.05.2020 20:32 # 9
gogly35
[QUOTE = 307 1.4 hdi] Have you checked the spark plug cables, sir? If there is a rupture in one of the cables, it will touch the motor, the chassis will be made and the coil will burn. You should have a check. [/ QUOTE]
The car lay in the authorized service for about 1 week. In this process, the spark plugs were all removed and they said that they had made the necessary changes, but it was obvious that they did not benefit.
08.05.2020 20:32 # 10
mami_35
I guess the 5th industry in Işıkkent is a top-notch automotive.
08.05.2020 20:32 # 11
gogly35
Friends, I did not understand whether the problem was solved or not, but I caught something.
While I was dealing with this problem before the feast, I used my car in gasoline for 2 days. I did not have any problem on the 3rd day, but since I was going to go a long way, I switched back to LPG and the problem continued. During this period, I linked the disappearance of the problem to chance. Since last week, I have been using my vehicle again in petrol and I have no problems. The problem you will understand is caused by the lpg system. The engine of the vehicle is flowing like a monster right now ..
So what do I need to do for LPG after which parts need to be changed. The other important point is there is a Zavoli dealer in Izmir that I can trust ???
08.05.2020 20:32 # 12
talip206
I wrote before, teacher, it is most likely that the cables pulled from the coil have either the wrong connection or the chassis. Did you make the lpg? It has 2 years warranty. If they are within the warranty period, they must bear all the costs of the image. I was interested in lovato, they were interested in the slightest problem for free. They even changed the brain a year later, without any charge.
08.05.2020 20:32 # 13
gogly35
LPG was active when I bought my car.
08.05.2020 20:32 # 14
gogly35
Unfortunately, the evil eye was worth it, I guess we had the same problem with the use of gasoline .. I went to another 1-2 service today said that the engine cylinder head should be removed and cleaned 2 people .. I'm very unstable ..
08.05.2020 20:32 # 15
Ufuk_64
How many kilometers of vehicles, it seems to me like a chain. What does it say when the fault is burned is how the exhaust failure vs. fuel rate shows, for example, how much the fuel is burning at a constant speed of 100 km, and if the fault light does not turn on, the gas response is the old values. Generally, if you think you are using LPG, you will not have such an institution in LPG vehicles. The master who says that we will open the engine will open the engine, then there is no such thing, it will officially be piled. It is useful to show the Pug service, you just need to know what they are saying, of course, not to do what they say right away. You'd better try what I said when you had the opportunity. It does not matter whether the engine is cold or cold. Stand on a ramped ground and apply the hand brake 1. Put down the gear and lift the clutch without throttle, so pull the car so hard that it will not stop, while the glass is open, does the repair sound sound. Unfortunately, I can not put that sound down in writing, if it sounds abnormal, you will understand something like takuk.
08.05.2020 20:32 # 16
gogly35
[QUOTE = Ufuk_64] How many kilometers of vehicles did I feel like a chain. What does it say when the fault is burned is how the exhaust failure vs. fuel rate shows, for example, how much the fuel is burning at a constant speed of 100 km, and if the fault light does not turn on, the gas response is the old values. Generally, if you think you are using LPG, you will not have such an institution in LPG vehicles. The master who says that we will open the engine will open the engine, then there is no such thing, it will officially be piled. It is useful to show the Pug service, you just need to know what they are saying, of course, not to do what they say right away. You'd better try what I said when you had the opportunity. It does not matter whether the engine is cold or cold. Stand on a ramped ground and apply the hand brake 1. Put down the gear and lift the clutch without throttle, so pull the car so hard that it will not stop, while the glass is open, does the repair sound sound. Unfortunately, I can not put that sound down in writing, if it sounds abnormal, you will understand something like takuk.
My vehicle is 157 thousand km .. when the fault is on, it writes exhaust emission failure and turns on the fan does not notice the hot and cold, but when the vehicle runs for a long time, it only gives fault warning, the engine improves in time or it starts to improve when the engine stops and restarts using this problem for 2 minutes. The masters who said we will turn on the engine were the peugeot service. While the motor is in the state of failure, the instantaneous consumption is constantly displayed as 0, but these figures reflect the consumption values correctly while the engine is running normally.
gogly35 2017-09-17 01:08:05
08.05.2020 20:32 # 17
Ufuk_64
I'm making a correction. Whether the foot is on the brake without applying the handbrake, try it a bit of effort, and try to get up without gasing while the foot is on the ramp.
08.05.2020 20:32 # 18
gogly35
[QUOTE = Ufuk_64] I'm making a correction. Whether the foot is on the brake without the handbrake, try it, it is a bother, and try to get up without gasing while the foot is on the ramp.
I will try it at the first opportunity and share it with you.
08.05.2020 20:32 # 19
Ufuk_64
It was like a chain to a large extent. You are lucky if 157 thousand km and no chain has changed. In most of these models, the chain elongates without 50 km. If the chain is too long, when the engine is cold, like the tractor, the engine runs for 1 minute, then the noise usually stops. But if you try as I wrote above, you will definitely come to the conclusion. I was not 25 thousand km long since I am 30 more happy I say. You have friends from the same engine, 85 bim km. There is a fee like 2000-2500 TL
08.05.2020 20:32 # 20
x571
[QUOTE = Ufuk_64] It looks like a lot of chains. You are lucky if 157 thousand km and no chain has changed. In most of these models, the chain elongates without 50 km. If the chain is too long, when the engine is cold, like the tractor, the engine runs for 1 minute, then the noise usually stops. But if you try as I wrote above, you will definitely come to the conclusion. I was not 25 thousand km long since I am 30 more happy I say. You have friends from the same engine, 85 bim km. It costs like 2000-2500 TL [/ QUOTE]
Come on I passed the specials, how the authorized service does not know. There are all kinds of diagnostic software. contact abroad. There is also a problem we can not solve. there is no one doing the job properly in the country. servicing and mastery consists of oil-filter-pad replacement. no more. Would it be a job like this or that?
Page : / 2
