Motor cups
08.05.2020 17:46 # 1
E.B
Guys I have not been able to solve the wheezing in the water engine that I have been doing for a long time. I showed it to the private service 2 times, I said to the peugeot service all the different things.
For a long time there was a whistling sound coming from the engine, this sound only comes on the move, so there is no sound at idle, oil is changed, oil filter has changed, carbon clean has not solved somehow, these are the results I got from the services I took.
The first one said that the sound of the transmission said that you need to change the transmission, or something, it is very expensive or something.
I took the 2nd to the peugeot service 2 times. In the 1st one, a normal voice was said to work 307 xs a little bit, but when the volume increased, I took it to the second time. This time we made a test drive. because there were 16 cups all
The third special service room told me that it could be from the cups, because I was in Cyprus, it was a bit difficult to find the piece
friends, I have a few questions
1. Do I need to replace 16 of these cups or is it enough to replace only the ones that are broken?
The second one did not say any service valve setting, but the valve setting comes to my mind, if I take it to the valve setting before doing these?
3. Finally, if I do not change these cups, if I continue with the thunderstorm, at least until the end of summer, will there be any problems?
Thanks for your help and answers ...
08.05.2020 17:46 # 2
maestro
If the problem is more than a cup, I have a problem with the cups, but I have a problem with the cup, but it sounds like it is stylish. of those who changed. Mine was changing one by one, the master still suggested changing all of them. Then in the first oil change, it was something like a pusher, like a cup cleaner, I added oil, I added it, because the air started to cool down there, the sound decreased, I observe, this sound was increasing especially in the hot and extreme stops, now the summer has come, the weather has warmed up well, but I hope there is no sound again. Now I don't know if it is the additive that solves the problem or the time, but I think it will not hurt to try the additive. let me see when i find the contribution.
08.05.2020 17:46 # 3
maestro
http://www.hepsiburada.com/liste/liqui-moly-lifter-katkisi-300-ml/productdetails.aspx?productıd=otson1009&categoryıd=26005&navq=fh_eds%3d%25c3%259f%26categoryid%3d26005%26fh_view_size%3d12% 26fh_sort_by% 3d-order_stock_attribute_pl% 252C-ranking_cocktail_bestsel are 26fh_maxdisplaynrvalues_brand%% 3d-1% 26fh_secondid% 3dotson1009 26fh_lister_pos%% 3D2% 26fh_locatio% of 3d 252F%% 252fcatalog01 252ftr_t% 253d% 252fbrand% 257bliqui20moly%% 257D% 252fcategories% 253C% 257bcatalog01_60002705% 257D% 253C 257D%%%% 257bcatalog01_60002705_2147483631 252fcategories 252fcategories 257bcatalog01_60002705_2147483631_253574%%% 253C 253C 257D%%% 252fcategories 257bcatalog01_60002705_2147483631_253574_26005 26fh_refview%%% 257D is 3dlist
08.05.2020 17:46 # 4
qqyyxx
In large-volume engines, there is a lot of wheezing sounds due to the engine noise, and if there is a different sound that is felt as a plus when it is loaded into the gas, a good pug or engine master understands that it should be at idle as far as I know, even if it is not excessive. otherwise it would be costly to act with assumption. I think it would be better if you wait until the problem becomes clear.
08.05.2020 17:46 # 5
maestro
[QUOTE = qqyyxx] If there is a different sound that can be felt as a plus when it is loaded to the gas due to the sound of the engine due to the engine noise, it is necessary to have a good pug or motor master understands the idle, as far as I know from the cups. otherwise it would be costly to act with assumption. I think it would be better if you wait until the problem becomes clear. [/ QUOTE]
I agree, the sound also happens at idle, increases in direct proportion to pressing the gas
08.05.2020 17:46 # 6
E.B
Thanks for your friends cwps, the sound I have noticed was the increase in the last time, but when I go to the service today, I heard my wheezing in the idle, but if I say I was grinning, I can hear someone else in the idle, even the master in the peugeot service but I heard it very comfortably, I heard the sound from the master, and I heard the sound from the 2000 rpm, But it does not hurt to take this additive that our maestro friend said, but since I am also in kktc, it is a little difficult to find the same brand.
08.05.2020 17:46 # 7
E.B
By the way, I changed the timing belt 2 months ago. Could the belt have skipped the sentence? If I had jumped, could I use it for 2 months?
08.05.2020 17:46 # 8
qqyyxx
If there is a problem with the sente setting, there will be more than normal vibration rather than sound. I do not know the 2.0 engines in the vehicle, but if there is no deviation in the sentence setting in 1, 6 hd, the vehicle will not start. Don't be too short of these chances of indentation or siren coming from the transmission. Because it can also be from balls that have changed.
08.05.2020 17:46 # 9
error
Hb, first of all, I have experienced what you have told one by one, you know it, you cannot explain this voice to the service. The guys are treating you crazy. Big smile
no one can say that the fault is, only the gearbox will fall, balls, etc. will be made, they will say that there will be 80% chance of sound.
The last word I was told was, "Don't ignore the brother, don't come to the service until the fault shows itself".
The same engine we have has 206 gti dada, but I used 16000 km, I did not hear one of the sounds in us at 206 gti, but in 206, the gearbox is different in this sense. Thumbs Up
08.05.2020 17:46 # 10
E.B
errör :) this problem really demoralizes me so much i think i will sell the car i bought 5 months ago seriously i was afraid to even hit the gas because of this sound, so i got a 307 xsi if i did not put it on the gas :)
08.05.2020 17:46 # 11
ismailkaya
EB IF my guess is correct if HALF HOURS VERY SIMPLE BUSINESS HAVE HIS FRONT WHEEL in THE LINING MECHANISM OF THE KIS FRONT WHEEL to fist with TIK TIK HIT hits IF wheezing OR THE OTHER TIRES to shoot the SOUND DIFFERENT FROM ONE VOICE HEAR they Firenc GO are DONE TURNING HEAR the BE EASY TO GET
08.05.2020 17:46 # 12
E.B
İsmail Bey is doing a different approach when he is on the move, but I will hear it at idle. Let's go down and try it. Let's see what happens.
08.05.2020 17:46 # 13
error
[QUOTE = EB] errör :) this problem is really demoralizing me that i think i will sell the car i bought 5 months ago seriously i was afraid to even hit the gas because of this sound i got a 307 xsi if i was going to put it on the ground because i will be something:) [ / quote]
don't be afraid LOL
08.05.2020 17:46 # 14
alp2525
I don't know exactly, but my old car had 307 xt sound, I showed it to a master outside, it hit the valve. may be brother
08.05.2020 17:46 # 15
ismailkaya
If you hear idling where you stopped, the problem is not caused by it.
