Motor breakdown
08.05.2020 21:19 # 1
atik
Greetings to everyone ...
I have been a pejo user for years, I cannot find the problem of my new vehicle and I do not want to make any expenses without knowing it in the repairers.
1) 308 vti 1,6 premu plus plus lpg / gasoline 80,000 km when the vehicle goes at lpg, it causes the engine malfunction lamp to come on after a while, there is no problem but the warning lamp is not pleasant at all.
2) How to fix the gasoline indicator falls at the same time when going with lpg these problems friends
Hi everyone with respect ...
08.05.2020 21:19 # 2
Karacocuk24
[QUOTE = agile] Greetings to everyone ...
[/ QUOTE] My teacher solves the 1st issue with a LPG setting made by a good master on the road
2. The problem is not actually a problem, especially in PSA group vehicles, this gasoline drop occurs. The vehicle calculates itself as it goes on gas.
08.05.2020 21:19 # 3
ismailkaya
which brand lpg kit is in your vehicle and one of the reasons for the malfunction of the malfunction lamp is not being installed well 2. the drop of gasoline is in most peugeot vehicles, as the friend says, keep the tank a little over half, and if you know the working principle of the float in the tank you will understand what i mean
08.05.2020 21:19 # 4
atik
thank you very much for your information
08.05.2020 21:19 # 5
atik
I have a Prins brand LPG in my vehicle, I had shaking before, I solved it. But I couldn't turn off the engine malfunction lamp.
08.05.2020 21:19 # 6
x571
[QUOTE = agile] I have a Prins brand LPG in my vehicle, I had shaking it before, but I couldn't turn off the engine malfunction lamp. [/ QUOTE]
There is Bandırma, not Bursa. I am satisfied. There was no problem. I have been using it since 2012.
08.05.2020 21:19 # 7
As our friends say, the reason why the LPG goes on for a certain period of time is caused by the rich poor man. The second is that most of the French vehicles get the same gasoline close to half a doping, as if it had enough gasoline, the light resets itself after a certain period of time.
08.05.2020 21:19 # 8
atik
Sa Friends 308 1,6 vti why the car does not heat the heater.
08.05.2020 21:19 # 9
If there is excessive dust residue on the radiator, it will not heat. The lpg water connection will not heat if the connection connections from this line are made incorrectly.
