MOTOR BLOWING
08.05.2020 16:25 # 1
emrust
Sa friends, we will get the 2000 model 306 xr platium, but there is a problem, we don't know much about the engine.
08.05.2020 16:25 # 2
yavuz25
circumcision is a cripple workaround, you can not ride it by mouth.
08.05.2020 16:25 # 3
emrust
So, does the print have anything to do with the pad?
08.05.2020 16:25 # 4
yavuz25
The print has nothing to do with the lining. The engine is worn and is about to reach the end of its lifetime.
08.05.2020 16:25 # 5
albayman
No matter how good the master engine master is, modern engines no longer get healthy information by opening the dipstick and gas. I personally did not trust, I did not.
The best thing is to go to the authorized service, make some money and time and get a multi-point expertise.
I know "Geek
08.05.2020 16:25 # 6
yavuz25
[QUOTE = colonel] No matter how good my master engine master is, modern engines no longer get healthy information by opening the dipstick and gas. I personally did not trust, I did not.
The best thing is to go to the authorized service, make some money and time and get a multi-point expertise. I know
"Geek [/ QUOTE]
it is important to be able to diagnose as my brother said.
08.05.2020 16:25 # 7
emrust
ewt I am with him (he opened the dipstick, did not provide the oil, when he opened the lid, there was no smoke, he just opened the entrance of a pipe entering the engine, he said blowing)
08.05.2020 16:25 # 8
yavuz25
If you liked the car, really show it to the service and decide accordingly.
08.05.2020 16:25 # 9
Ucyuzalti
If you blow the car with a blown and press pad, the engine will be out and the press pad will be lowered unless a good money falls & nbsp;
08.05.2020 16:25 # 10
albayman
my previous vehicle was 98 corsa gls 1.4 lpgli. Of the 90 horsepower. its previous owner was an opel authorized service consultant. I bought the car at an affordable price because it had pretreatment on its bonnet, but the walking engine was super, and I bought the car at 146 thousand and used 30 thousand km, there was no complaint since the engine was walking outside the coil.
& nbsp;
we went to a random opel engine master within the industry. The man opened the hood, pulled the dipstick, pulled the gas choke, shouted the engine. He said that this engine is dead, there is blowing, it burns oil. He took a turn, said the pads are about to run out, the brakes are not good. I said ulen you, and you who came to you ... There was a problem with the air conditioner button (the man had just changed, changed from the warranty again.) The front suit and the engine transmission chocks said his ears or something, I changed it to the man) The engine gave 83 horsepower in gasoline. 79 hp at lpg. It was said that the engine is walking well, it does not burn oil.
08.05.2020 16:25 # 11
yavuz25
[QUOTE = Three Hundred] The blown and thrust pad will be out of the car. Unless there is a good amount of money, both the engine is out and the thrust pad will be lowered. & Nbsp; [/ QUOTE]
my brother is just a press pad motor, good axles, balls, what's going on.
08.05.2020 16:25 # 12
emrust
The reason for our purpose of destroying the original car of the car is that it fell from the price of the car after that.
08.05.2020 16:25 # 13
yavuz25
The engine will not be stabilized with circlip, think of the revision money, plus the price of the press pad, and at worst, you will spend a little more on it.
08.05.2020 16:25 # 14
emrust
good problem only on the front set of the car print pad and blowing
08.05.2020 16:25 # 15
yavuz25
[QUOTE = yavuz25] With the circlip, the engine will not be strong, think of the revision money, think of the price of the press pad, plus the price. src = "smileys / smiley1.gif" height = "17" width = "17" border = "0" alt = "Smile" title = "Smile" /> Go to the service and check the engine, consider the costs.
08.05.2020 16:25 # 16
emrust
Thank you for the information, it is best to take it to the service comfortably
08.05.2020 16:25 # 17
yavuz25
Thank you. You'll be comfortable with the service. "Wink"
08.05.2020 16:25 # 18
Ucyuzalti
In the cleanest 2nd hand, you will spend 500 TL again, it is fixed with co-operation. , the second hand car will be my brother, the press will start the car, but the ring will drop, the car will make the car will not be kept straight, the engine will be made satin for 1 year, the printing will be made of satin, the bidet will have an extra cost .... etc then the car will damage the bullet Buy a clean car engine will satisfy your eyes and say that the model's car will be like a good ride. Do not mind the paint on the car's decoration, because with the car paint & nbsp; doesn't work with steel rim "Big
08.05.2020 16:25 # 19
yavuz25
[QUOTE = Üçyüzaltı] In the cleanest 2nd hand, 500 TL is spent again, it is fixed with tevçube, I advise you to find a clean vehicle, because the ring does not get better with the ring, the master must do it well, you need to do it well or you will get into trouble again now! I will say that I have a dream, I will say that my car will be used as a second-hand car, but the car that will drop the ring will fall off, the car will be held for 1 year. = "smileys / smiley36.gif" border = "0" alt = "LOL" title = "LOL" /> then the car will damage the bullet " Buy a clean car engine will satisfy your eyes like this. Do not mind the paint on the car's decoration, because with the car paint & nbsp; doesn't work with steel rim "Big
& nbsp;
A word came to my mind. "To some extent in makeup." "LOL"
08.05.2020 16:25 # 20
Ucyuzalti
Exactly, my car has the same white 306, the man has done it, the car has been really beautiful, I met him in the car, we came across the passing ring road, the flooder, the artist, the movements and the abart exhaust, the basement, the gasoline, I fell on the gas pulled & nbsp; "LOL" " will look at the rimmed engine but I looked in the mirror, face & nbsp; such & nbsp ; zuhahaha & nbsp; "Big
Page : / 2
