motor blowing
08.05.2020 14:07 # 1
What is the so called engine blower? & nbsp;
08.05.2020 14:07 # 2
"Ermm"?
08.05.2020 14:07 # 3
does not anyone know ???
08.05.2020 14:07 # 4
Haşim ustaaaa !!!
you just solve this event :))
& nbsp;
08.05.2020 14:07 # 5
car is diesel or diesel, there are double eccentric mlii on top models, it is normal for oil to throw, let's not smoke. oil vapor !!! Even when zero oil of the zero car is working, open smoke comes in. It is the working system of the car. If the smoke from the exhaust is white and lush, this is the real danger. For best understanding, look at the exhaust black dumansa injectors and the pump is over white and lush. The engine is over. Do not open the oil cap of the working car "Angry" "Angry"
08.05.2020 14:07 # 6
thank you polat captain car 16 petrol! I heard somewhere, I opened the engine oil cover to look at it, there is no smoke at all, but according to the movement of the piston, it seems like the blower war chamber is going up and down according to the movement of the piston & nbsp; I pulled the dipstick the same thing is not it
08.05.2020 14:07 # 7
THE EVENT IS VERY DIFFERENT IN GASOLINE. IN THIS WAY UNDERSTANDING OIL EXTRACTION AND EXTRAORDINARY OIL COVER & nbsp; DOES NOT BLOW ON THE FINISHED MOTOR
08.05.2020 14:07 # 8
When you say it doesn't blow, I think it means there is no smoke because the air is coming "
08.05.2020 14:07 # 9
gasoline doesn't smoke anyway, air comes, but oil vapor comes out.
08.05.2020 14:07 # 10
I asked the service 307 diesel engine said different, he said there would be no such thing as blowing
08.05.2020 14:07 # 11
H-a-d-i
[QUOTE = kundun]
& lt; FONT style = ": # 9cb9e1" & gt; saolas polat captain car 16 petrol! I heard somewhere, I opened the engine oil cover to look at it, there is no smoke, but according to the movement of the piston, it seems like the blower war room is going up and down according to the movement of the piston. > [/ QUOTE]
you said it was caused by piston movement. Was the car on the lift while you checked?
08.05.2020 14:07 # 12
neey !! What is the lift? "C
08.05.2020 14:07 # 13
my polat captain vehicle is not a 1.6 petrol diesel!
08.05.2020 14:07 # 14
H-a-d-i
[QUOTE = kundun] neey !! What is the lift? "C [/ QUOTE]
< img src = "http://img96.imageshack.us/img96/567/pr0111247max.jpg" border = "0" />
08.05.2020 14:07 # 15
was on the ground
08.05.2020 14:07 # 16
Does it make a difference if it's on the lift or on the ground?
08.05.2020 14:07 # 17
H-a-d-i
If the vehicle is stationary on the ground, it is not caused by the blowing piston movements in the dryer setting you mentioned.
because if the vehicle is stationary, even if the engine starts, the pistons do not play (get up and down). If you open the door and start the car anyway, not only the blowing, but also the oil will come out, your mouth will become the oil.
So, you guessed it from the blow piston movement. expression was wrong. because when you saw the blow, the pistons were lying in their places like a lion.
08.05.2020 14:07 # 18
cerci07
The brothers usually use the blower for the old tufas. You can not understand that the engine is coming in these new model vehicles by opening the oil cover. Do not miss the oil.
08.05.2020 14:07 # 19
cerci07
[QUOTE = h_307]
because if the vehicle is stationary, the pistons will not play (go up and down) even if the engine is running.
brother, I couldn't understand the water part, how is that happening?
08.05.2020 14:07 # 20
The engine will not run without the wrong brother of the wrong piston moves "Big "Big "Big
Page : / 3
