most front panel lights are on, airbag off
08.05.2020 14:05 # 1
I have a 2002 307 xr gasoline 1.6 car owner, while the vehicle has been driving for the last week, the warning lights on the front panel are on, it goes off after 15-20 seconds, but the front passenger airbag lamp (OFF) is on. I reside in Ankara. , I am not waiting right now, the new brain is a bit expensive, the masters are going to clean it, but your car may not work at all, if you take this risk, they said let's decide I could not decide, I will ask you for help or comment,
peugeot 307 xr
2002 model ( petrol + lpg)
manual gearbox
08.05.2020 14:05 # 2
ErkanKurnaz
get well bro, I'm sure my friends will help
08.05.2020 14:05 # 3
delcullu
get well, my friend. I will also wash the engine, but I'm afraid that water will escape. I couldn't wash it.
08.05.2020 14:05 # 4
peugeotefe
brother will help see the issue
08.05.2020 14:05 # 5
hasimayaz
Unfortunately, the BSI is right next to the door sill. It is susceptible to any leakage that may occur in windows or glass. Just below the fuse box on the driver's side. Especially, the opening of pedal wires and door tires may cause bsi to get water. The most logical thing to do right now is to clean it with contact cleaner or sf alcohol. It will be heated by air soldering iron. But before disassembling, which is very difficult to disassemble. external sockets can be cleaned and checked.
08.05.2020 14:05 # 6
fatih1903
[QUOTE = delcullu]
get well, my friend. I will also wash the engine, but I'm afraid that water will escape. I wasn't able to wash it. If there is a water running out of the brain, then mazallah:) & nbsp; I wouldn't recommend ... :)
