morning work
08.05.2020 19:08 # 1
2004partner
hi everyone i want to convey a problem about my 1.4 gasoline / lpg 2004 model partner car thanks for your help in advance :
morning my vehicle before misfire begins after working car RUN I do not eat gas later when starting to shake Noises from the exhaust approximately ba minutes later, she said Download the coil over the hump, I showed a few craftsmen are from someone else sPAP settings did sPAP settings but still the same problem continues Cry
please write someone to help ClapClapClapClapClap
08.05.2020 19:08 # 2
_ali_
I saw about 10 topics in the forum about it, something different happens in each vehicle, my recommendation for this malfunction that even the masters try trial is to start with the cheapest solution.
In some vehicles, LPG is due to low transition temperature, turn off the gas and use the vehicle for a couple of days for detection.
08.05.2020 19:08 # 3
2004partner
there is the same problem with gasoline ali sister .....
08.05.2020 19:08 # 4
peugeot murat
DOES THE SMOKE
08.05.2020 19:08 # 5
2004partner
yes there is the first study in the morning smoke
08.05.2020 19:08 # 6
2004partner
Yes, there is the first study in the mornings. Do you have any information about smoke, gasoline filter?
Smile
08.05.2020 19:08 # 7
peugeot murat
Presumably when your car Valve OIL TIRES OR when YAK the PISTON TOP to downloading MORNING RUN greaseable Bujar of ON THE OIL BURNING UP sputters The burned on them recover SUBJECT THIS IS MY PREDICTION I SEN BEN CE VEHICLE OIL AUCTION THERE FOLLOW THE YACHT USTA to EVENING than VEHICLE LEAVE THE MORNING COMES He BAKSIN run
08.05.2020 19:08 # 8
2004partner
T AHMİNEN YOUR CAR'S VALVE TIRE OIL TIRES SmileSmileSmile I couldn't understand this sentence
08.05.2020 19:08 # 9
peugeot murat
[QUOTE = 2004partner] T AHMİNEN LAYS YOUR CAR's VALVE OIL TIRES SmileSmileSmile I couldn't understand this sentence [/ QUOTE]
OUR FARKETM DEFECT LOOKING VALVE OIL TIRES OILS OVER CYLINDER OIL
08.05.2020 19:08 # 10
peugeot murat
SEND CHASSIS NUMBER TO ME
08.05.2020 19:08 # 11
2004partner
I will meet with the master now, I hope I can relax from him, Ali brother, I am very bored CryCry
08.05.2020 19:08 # 12
peugeot murat
MURAT PEJOCU MURAT IS NOT ALI ...
08.05.2020 19:08 # 13
2004partner
95034232
