mop making water
08.05.2020 20:59 # 1
butterfly
Hi friends,
On the right side, it was rusting, it was getting wet, I noticed the other day.
I have a pool mat in my car, where does this water and moisture come from? This topic is missing my pleasure: ((((I would be very glad if you helped.
08.05.2020 20:59 # 2
butterfly
Yeah. possibly from rain gutters. The water extraction problem arises even if the heater is from honeycomb. no water subtraction. tomorrow I will follow the groove expense.
08.05.2020 20:59 # 3
talip206
If my brother is 206 and the passenger side is getting water, the place to look is the door. When you remove the flooring on the door, there is a nylon underneath, and if it is torn, it does not let the water into the downward drain hole. Especially when the speaker or something changes, that nylon tears in general. talip206 2018-08-12 00:21:50
08.05.2020 20:59 # 4
butterfly
If I can remove the vehicle 407. from the water channels tomorrow first place to check the first temperature.
