misting problem
08.05.2020 16:14 # 1
tilbe307
my friends car is unbearable when winter comes. especially the rear windows are very foggy. Is there a solution? & nbsp;
08.05.2020 16:14 # 2
DRIVER34
If there is no resistance, there are some sticking ones. I don't know if there is still some or you can use an anti-fog ... & nbsp;
08.05.2020 16:14 # 3
orhanax
Also, if you leave the windshields open half a finger, it will be very useful during the journey. Of course, it is necessary to be careful not to let water in the rainy weather. :)
08.05.2020 16:14 # 4
I bring out the temperature of the boiler and always keep it on level 1. If it's too hot, I open the car right window slightly. & Nbsp;
08.05.2020 16:14 # 5
It does not give the best boiler to the windshield in hot mode or soak the glass and wipe the glass, leave it slightly foamy, and then dry it on its own.
08.05.2020 16:14 # 6
metin
[QUOTE = DRIVER34] If there is no resistance, I don't know if there are glue ones or you can use anti-fog ... & nbsp; [/ QUOTE]
& nbsp;
How did you know that you don't have resistance?
08.05.2020 16:14 # 7
Ako06
I think it makes the most sense to open the boiler and give it to the windows.
08.05.2020 16:14 # 8
Long Beach
& nbsp; supply / direct the air blowing of the boiler to the windshields. Even if the heating engine is not on, it prevents fogging with the engine temperature. When the person enters the car with wet-snowy feet, there is still steaming inside, there is no resistance in the windows, there are small and thinly designed heaters made for the vehicle that follows the plug.
08.05.2020 16:14 # 9
tilbe307
thank you friends for ideas yes you know most of them as a method but when a few people get into the vehicle, especially the windows are completely mist. I'd say let's take a look at this liquid soap business :) thanks & nbsp;
08.05.2020 16:14 # 10
Long Beach
I think a heater like in the picture solves its problem,
or this a heater in figure
[TUBE] ShkxExid2Kg & amp; feature = player_embedded [/ TUBE]
08.05.2020 16:14 # 11
Engin Tepe
Antifoggers sold in auto markets do the job, but buying from 1 millioniers doesn't work :)
08.05.2020 16:14 # 12
DRIVER34
[QUOTE = text] [QUOTE = DRIVER34] If there is no resistance, I don't know if there is still a stick or you can use an anti-fog ... & nbsp; [/ QUOTE]
& nbsp;
ee got steam .... & nbsp;
is not working anyway, I thought, by the way, when I read carefully, I noticed the rear windows, I perceived it as the rear window ... & nbsp; "C
08.05.2020 16:14 # 13
_ali_
I hose down the subject, but there are a lot of people who think that the anti-fog spray does not work, my application is as follows:
I loosen the anti-fog spray cap a little and keep it in boiling water for 5 minutes, then I go to the car and take the dust from the glass with a dry cloth, the hot spray will not drip. I squeezed it in density and let it dry completely, then I wiped it gently without pressing it with a clean lint-free dry cloth. No longer mist.
08.05.2020 16:14 # 14
furkanyakar
[QUOTE = _ali_] I hose down the subject, but there are a lot of people who think that the anti-fog spray does not work, my application is as follows:
I loosened the anti-fog spray cap a little 5 minutes in boiling water, then I went to the vehicle and took the dust from the glass with a dry cloth, etc. I squeezed the hot spray to a density that it would not drip and let it dry completely, then I wiped it gently without pressing it with a clean lint-free dry cloth. No longer mist. [/ QUOTE]
you tried, so this is OO
08.05.2020 16:14 # 15
ufuk91
I'm having the same problem nowadays ... Let me try this soapy cloth
08.05.2020 16:14 # 16
_ali_
[QUOTE = furkanyakar]
you have tried so oO
I did it last week and since then there has been no condensation, I don't know how much it goes, cleaning the windows etc. I think it goes until I do it.
08.05.2020 16:14 # 17
yavuz_0051
08.05.2020 16:14 # 18
Mesut48
Wipe with pure alcohol. First clean the glass dry, then switch to alcohol and then clean the cloth will not mist if the heater is intact.
