Missing nut?
08.05.2020 18:01 # 1
gokhn89
The nut on the right side where the turbo is attached is not on the left side, and there is oil leakage from there, is that oil due to missing nut or is there no 206?
08.05.2020 18:01 # 2
Serkan
Hodja, now I looked at 4-5 engine pictures from google, there is no nut in any of them, I put it as an example in the picture below.
So I copied the picture of the stuck location.
Serkan 2013-10-24 21:34:31
08.05.2020 18:01 # 3
gokhn89
I wonder what the oil is like :)
08.05.2020 18:01 # 4
Serkan
Seals leak slightly if worn.
08.05.2020 18:01 # 5
gokhn89
thank you for your interest :)
08.05.2020 18:01 # 6
qqyyxx
one side is screwed and the other is screwed. Since there are orings in between, the oil will leak, and the problem will be solved by buying new in old oring size.
