Misfire tremor lpg in gasoline tremor
08.05.2020 21:23 # 1
balkespejo
0
Friends selamünaleyküm 2001model Pejo 307 1.6 16 V 110 Horsepower I have a gasoline and LPG vehicle, and for about 6 days I knocked on the door of all repairmen, but nobody was able to worry about my problem. It passes directly to the gas, shivers and stops, and the car goes uphill on the lpg, trembling gas cuts, pulls aside, stops and starts, then improves, as well as other errors like Bi, Antipllution and Catalty Conv. besides giving error, but still we could not get a positive result, I looked at the firel, I saw friends who wrote articles close to this problem before, what was their solution or have there been masters who know about my solution? if any, they can reach me cvplas ....
08.05.2020 21:23 # 2
First of all, welcome to us. First of all, you need to solve the problem in gasoline. spark plugs - coil - petrol injectors - petrol pump - electrical wiring check should be done. throttle cleaning is also important.
08.05.2020 21:23 # 3
omerb
welcome to us As Soner said, firstly disconnect the LPG.
Maybe the problem may be caused by lpg.
Lpg kits are connected as follows.
They copy the values such as injectors, maf and map sensors from the vehicle's ecu and enter the lpg brain.
When the vehicle switches to LPG, they close the fuel injectors and open the LPG injectors.
Maybe the lpg brain is interfering with local gasoline injectors. It may provide gas flow when the vehicle is lpg. You can control this too. Take out the fuse of the lpg kit. Just try. If you smell gasoline and lpg, please disconnect the vehicle from the battery. Be careful please.
08.05.2020 21:23 # 4
balkespejo
today I noticed Bi incident vehicle catalytic connector malfunction lit the oxygen sensor in the engine compartment, I dismantled the casing casing, the casing was black and exhaust manifold engine block entry 3 4 cracks, this affects the car traction, now the car is cutting gas on the ramp
08.05.2020 21:23 # 5
omerb
If the cracks are small, I think nothing will happen.
It gives its catalytic failure from rich mixture. First check this LPG system and ignition system. The ignition coil may be oxidized. It happened to me the other day. The two biggest reasons for vehicle misfire incident, fuel and ignition system
08.05.2020 21:23 # 6
Ako06
Years ago antipollution fault and catal. Converse. I had the error. Mine started to stop as soon as it worked. The spark plugs and coil changed and the problem was solved.
08.05.2020 21:23 # 7
arasemre
I dealt with antipollution fault malfunction. When it was bought in gasoline, the car was perverting. Enson will ride in a master petrol, these vehicles said they would not sew the tube and calibrated the throttle. We took out the tube insurance right now, no problem. The same brand has the same model friend, the same as the same waste tube tube. It's okay in lpg and gas. Even the malfunction lamp does not light up. I couldn't make sense and I'll see another master tomorrow. Let's see what he says.
I'm not sure if your vehicle may not be calibrated. If it can be done, get it done first, then go to track replacement.
08.05.2020 21:23 # 8
balkespejo
so how do we cancel this lpg insurance
08.05.2020 21:23 # 9
x571
[QUOTE = balkespejo] so how do we cancel this lpg Insurance [/ QUOTE]
I'm just looking for him. How do we get insurance, where is it, what is it like
08.05.2020 21:23 # 10
omerb
Look at the lpg brain. Follow his cable connections. It is on the cable connected to the battery.
