misfire shaking idle solution
08.05.2020 17:59 # 1
radikalsovalye
hi 15 days ago I rejoined the peugeot family. 2 pejoms had been before 504 and 505 already bought 206 now 2000 mod 1.4 lpg li mornings, the first start was to stop, and the engine was getting better and the ignition was changed. I solved the problem in the following way, I bought 30 TL gasoline, 5 TL injector cleaner additive (there are gas stations), then I removed the hose that went to the throat from the filter, clean the butterfly throat with wd40 (5tl) with a cloth, then dismantled the idle valve, the tip of this valve turned out to be something that turned black again wd40 I squeeze it and play it nicely with the header, I removed the pressure sensor in the same way with allen and clean it and put it back in place (this requires a bit of expertise). I r.
the result:
misfire is up
performance increased
single starter smooth idling
comfortable departure
expense account:
30 TL gasoline
5 tl wd40 (small size)
Total: 40 TL
the pressure sensor is removed with a single screw star allen T40
The idler sensor has one more screw on the lower cross of the yellow round with two allen screws
Removed with T 20
remove the battery terminal (+) before removing the pressure sensor and rolati sensor
Unscrew these two screws to clean the butterfly throat below the small attached hose
remove the hose aside by pressing on the yellow strip as I mentioned
If we look into the throat after removing the hose aside, how dirty
by squeezing a clean cloth wd 40 slowly around the throat
Let's clean the dirt accumulated like black and black as much as our finger can enter
let's open the throat and clean it thoroughly by holding the gas valve in between.
then place them again and again without carefully rushing them into place.
Let's check it out
I hope your problems will be gone by this way
radikalsovaly to 2013-10-15 12:10:58
08.05.2020 17:59 # 2
pusutr
Health to your hand. picture / video are welcome.
08.05.2020 17:59 # 3
samet206
If you take detailed videos or pictures, good health work will help you. I have glazing in my car, nothing is less on start-up, there is no irregularity in idling, but I do or do what you call.
08.05.2020 17:59 # 4
erden1978
WD 40 Good to be beautiful.
It gets worse in 1 week wd 40 squeezed places.
Also, it is hard to guess how much invoice you were to go to industry for these failures Big smile
08.05.2020 17:59 # 5
gokha_nn
I think a temporary solution will be the same again, but in the first edap you will not get worried about following the head
08.05.2020 17:59 # 6
radikalsovalye
It has been 1 week now, the problem is gone, I hope I will shoot the video and send it.
08.05.2020 17:59 # 7
Ahmet_ach
very useful sharing, I do the same, I clean my throat butterfly and its elements every 2 months, the result is temporary but after 2 months or more, the idle becomes unbalanced again. The throat butterfly, cleaned with 40, draws more dirt dust.
08.05.2020 17:59 # 8
yavuz_0051
I do not understand why we disassemble the pressure sensor and the battery terminal.
08.05.2020 17:59 # 9
elsoberano
thanks for sharing.
08.05.2020 17:59 # 10
kuscu38
nice sharing i think thanks ... for friends who do not know how to protect them from repairers trying to pile up informative :)
I agree with my friend ahmet balata spray is perfect for such problems. The wd 40 dust accumulates dirt as molding.
08.05.2020 17:59 # 11
radikalsovalye
The pressure sensor can be simply swept with a single wrench, when you remove the sensor, you can see the oval hollow small circle, again by spraying it and shaking the sensor and then put it back.
After doing these operations without forgetting, I burned an average of 100-120 km speed between Istanbul and slightly high traffic use 19 cents. I got your information from shell lpg 2.62
radikalsovaly to 2013-10-18 10:09:57
08.05.2020 17:59 # 12
radikalsovalye
After doing these operations without forgetting, I burned an average of 100-120 km speed between Istanbul and slightly high traffic use 19 cents. I got your information from shell lpg 2.62 radikalsovaly to 2013-10-18 10:06:01
08.05.2020 17:59 # 13
erden1978
@radikalsovaly to
What is the function of the pressure sensor?
08.05.2020 17:59 # 14
radikalsovalye
What does a map sensor do?
• This sensor sends data to the ECU (vehicle brain) based on the amount of manifold pressure. Ecu adjusts its advance and the amount of gasoline accordingly. MAf sensor located on Manifolt
08.05.2020 17:59 # 15
yavuz_0051
why are we disconnecting the battery terminal?
08.05.2020 17:59 # 16
radikalsovalye
the battery terminal is removed for precautionary purposes
08.05.2020 17:59 # 17
Burak
congratulations good sharing thanks
08.05.2020 17:59 # 18
dukenukem82
I have no problem these days, but I will try what you say.
08.05.2020 17:59 # 19
ikurklu
Friends,
my car is 1999 model 206 1.4 XR petrol automatic. I own the 3rd at 13000 km. I also had a serious tremor, even hard work, at the first start. For this reason, I took it to the authorized service 2 days ago. And before I took it to the authorized service, I had the throat butterfly cleaned in the nearby industry.
140000 maintenance was also carried out in the service. A lot of things have been renewed. (Battery, coil, spark plugs, timing set, engine oil, all filters etc.) But my car still vibrates at the first start. How to solve this problem, I would be glad if there are friends with suggestions and information.
Thanks.
08.05.2020 17:59 # 20
koramiral
If it cuts when heated, check the v-belt and its tensioner, most likely the belt will cut the knock for 35 tl. It is fixed with the trial.
Page : / 2
