Misfire Problem in Lpg?
08.05.2020 20:19 # 1
AykutAykut
First of all, hello everyone, I am one of the new joins.
I bought a 2011 model 206 + about 1 month ago. I have a BRC brand tube in my car. My car makes a slight misfire when I pull my feet from the gas while I am on the go, and it does this every time I press and pull the gas. my problem did not improve. the coil was inserted, the problem in my vehicle did not improve, these coils were not original, the bobbins went out from the bazaar and said that it was necessary to buy a coil, we went with the master, we tried 3 coils. I did not need to try and plug in the brain, but it didn't make sense to me, because if I don't try to get a brain like 600 pounds, if I don't try to brain it, I said I shouldn't give 300 pounds of workmanship, and I said that if you have information about this subject, it is very annoying. I have a good day ...
08.05.2020 20:19 # 2
First of all, welcome to us. We wish you to use your vehicle without accident and good luck. When it comes to the problem, the misfire thing just makes lpg demi. Is there the same problem in gas?
08.05.2020 20:19 # 3
KILIC
Teacher, clean the plug on the gas pedal. Which is connected to the accelerator pedal.
08.05.2020 20:19 # 4
Baran35
I don't know if our problem may be the same, but did you have it connected to the PC and set the gas :)
08.05.2020 20:19 # 5
AykutAykut
Thank you ... I did not realize much, but the master said he is doing in gasoline. I made the gas adjustment 3 times and it is not related to the gas adjustment.
08.05.2020 20:19 # 6
First of all, if the engine has the same problem in gasoline, it is necessary to solve it. The LPG setting is in the second plan, it usually makes this misfire problem when the engine is cold.
Deactivate the 1-lpg system (close the fuse and close the lpg tank valve)
2-replace gasoline filter
3-Have the gas pump checked
4-throttle cleaning and adaptation
5-150-200 km of your servant (observe if the problem persists)
6-If the problem passes, make the settings of the lpg system.
08.05.2020 20:19 # 7
direksiyon hocasi
the same problem I couldn't find in my vehicle, it was very annoying. Cry
08.05.2020 20:19 # 8
[QUOTE = steering instructor] the same problem is in my vehicle, we couldn't find the care is very annoying also, anyone knows how to improve the idle adjustment in +206 ?? Cry [/ QUOTE]
First of all, welcome to us. Check if the idling setting is doing the same problem on our vehicles automatically as I said above. use the vehicle on gasoline 100-150 km idling is getting better.
08.05.2020 20:19 # 9
iammanover
It is annoying to get past brothers,
The problem with the map sensor might have happened to me. Don't worry, don't let me control the brain. The vehicle gets the highest km. :)
08.05.2020 20:19 # 10
sdttn
[QUOTE = AykutAykut] First of all, hello everyone, I am one of the new joins ...
I don't know if your problem has been resolved.
What exactly was the malfunction code?
It looks like an electrical problem. LPG may have incorrectly connected the order of the encoder cables. Connect the injector wires directly to the gasoline injectors (as in the original) and try.
