Misfire problem
08.05.2020 16:31 # 1
serommm
Friends, 306 cars were kicking. In the past, we went to the master, he said to look at the gas setting.
They went to the place of the lagoon, they adjusted my car. They said this problem did not ignite. The vehicle started to misfire. And while the vehicle was idle while waiting in red, the engine malfunction lamp came on. But when I gas it it goes out. div> and the car stopped on the road idle on the day of the adjustment, but once it did.
Is there any trouble happening to me before? If anyone knows the solution, I would be happy if it helps.
There is no misfire problem in gas, only in gas. Spark plug cables changed 30,000 km ago. Does it have anything to do with it?
Thanks in advance r.
08.05.2020 16:31 # 2
yavuz25
[QUOTE = serommm] Friends 306 cars were misfire. We went to the master in the past, he said, take a look at the gas setting.
I have a lavato brand sequential system in my car. We went to the place of the lavato and they adjusted my car.They said this problem without firing. However, after the man made adjustments, the vehicle started to misfire. And while the vehicle was idle, while waiting in red, the engine malfunction lamp came on. But when I gas it it goes out.
On the same day the setting was made, the car stopped when it was idle on the road, but it did it once.
Did anyone have any trouble before? I would be happy if anyone knows the solution.
Gasoline does not have a misfire problem, it is only in gas. Spark plug cables have changed 30,000 km ago. Does it have anything to do with it?
< / div>
Şimdid Thanks a lot. "0" alt = "Wink" title = "Wink" />
yavuz25 2012-01-15 09:34:38
08.05.2020 16:31 # 3
ByHack
As my brother "yavuz25" stated, especially replace the spark plugs, do not forget to replace the LPG filter. Especially if you are using LPG with additives, it is better to change the filter at least 15.000km. I changed the filter last week since I bought the car 12,000km I did not know when the owner had changed before me, but believe me there was a residue like grease oil, which I do not buy from anywhere other than PO or & nbsp; OPET & nbsp; & nbsp; LPG. The misfire-frustration problem you mentioned has disappeared after the filter and spark plugs have changed. He was doing a lot of frustration especially in 2nd gear. With the hope of solving the problem as soon as possible, salute ...
08.05.2020 16:31 # 4
serommm
Thank you guys.
The LPG filter has not been replaced by 5000 km but I will change it tomorrow. we take it to the service.
May God bless our end :)
< edited> serommm 2012-01-15 20:07:01
08.05.2020 16:31 # 5
yavuz25
[QUOTE = serommm] Thank you guys.
The LPG filter has not been replaced by 5000 km but I will change it tomorrow too. Let's see if we take it to the service tomorrow, including the heavy maintenance.
take some money with you. "LOL" May God help you. < img src = "smileys / smiley2.gif" border = "0" alt = "Wink" title = "Wink" />
