misfire on first departure
08.05.2020 16:57 # 1
burak45
The 2008 model has 1.4 90 horsepower and 307 im. This is a week or two, when I run my car in the morning, or more precisely for the first time on that day, my car is singing. It seems to stop. Then it continues as if there were no problems. Spark plugs have changed, what are my gas butterflies, they have been cleaned ... etc ... Please help. If we stay in the industry, they will change all parts of the vehicle .....
"Cry"
08.05.2020 16:57 # 2
dukenukem82
he stops at the first run, and then he works as tiritritirina when he is idling. There is no problem in the performance, but there is no problem in the .lpg. Is there anyone who will show the butterfly cleaning with a picture and if anyone has found a solution after this problem, how did they handle it?
dukenukem82 2012-08-03 07:09:57
08.05.2020 16:57 # 3
Cmoss06
I think the malfunction of the idle sensor may be
08.05.2020 16:57 # 4
burak45
they cleared the throttle, the spark plugs changed. the fault has not changed ............
08.05.2020 16:57 # 5
burak45
I took it to another master. He said from the gas settings. I was told to those who wear a lot of brc. I will go again tomorrow, the master will adjust the gas settings. Then I will go back to brc. I will ask them to make lpg gas settings ....
08.05.2020 16:57 # 6
xxumutxx
For the complaints such as not eating gas and swelling the gas in cars with LPG, stop by a master who makes carbon clean and say that you only want to clean a catalatic converter and give a maximum of 30 TL.
The action the master will do
fill the carbon clear liquid into a half-tube spray and squeeze it directly onto the road leading to the catalatic converter. You will see that the misfire has changed.
The master in kadosan is highly recommended.
08.05.2020 16:57 # 7
burak45
I was a master today. the vehicle remained there until evening. "I used to adjust the gas," he said. He dealt with something like a butterfly, etc. no parts have changed. The vehicle has survived the trouble for now. I'll try again tomorrow morning. Let's see if the problem continues.
