misfire on engine
08.05.2020 15:20 # 1
efsanemurat
slm, while my engine is running at idle, sometimes the engine's running sound changes for a while, it runs normally then suddenly the idle falls a little, as if the engine is getting clogged again, it improves at idle, it makes a continuous break, the sound is normal, as if suddenly yelling, I showed it to the master. As long as I was up, the sound improved, the engine worked very well, I came, I listened today, the engine did the same again, I did not clean the tank, I did it.
08.05.2020 15:20 # 2
berk2309
My brother Arban, dearly, we are in the pejo boxer, unregulated caliodu engine next to the engine, the engine, the intelligent, they said that they injected the injector when they were in contact, we did it in the original pejo service.
08.05.2020 15:20 # 3
efsanemurat
I wonder how much it cost me if I clean my injectors
08.05.2020 15:20 # 4
metin
it may be from the fuel you take.
08.05.2020 15:20 # 5
I Had 307 Many Misfire Problems In Generally When I Was Taking Fuel From OPET It Happened To Me.
08.05.2020 15:20 # 6
efsanemurat
After cleaning the throttle, was the problem over? It doesn't happen all the time. It may be from bad fuel.
08.05.2020 15:20 # 7
You can use injector cleaner diesel additives. Products of Carpex are sold in shopping malls.
08.05.2020 15:20 # 8
ismail ozdemir
[QUOTE = ColonelDemircan] I Had 307 Many Misfire Problems, Generally, When I Bought Fuel from OPET, I Had My Throttle Cleaned I [/ QUOTE]
I have 307 in me, I appreciated the LPG last year, I have been buying gas only for 1 year.
08.05.2020 15:20 # 9
sedat23
My ex was doing it in 307, meanwhile, I was buying petrol from the opera, it was both next to the workplace and the symptoms you said were falling out of traction.
08.05.2020 15:20 # 10
ismail ozdemir
Exactly, brother dustu tool did you solve the problem already?
08.05.2020 15:20 # 11
sedat23
I changed the gas station, I started to buy it from the oil office, my friend returned to normal on the traction, but let me ask without forgetting, did you change the pressure pad these days?
08.05.2020 15:20 # 12
ismail ozdemir
I am a vehicle truck
08.05.2020 15:20 # 13
ismail ozdemir
your vehicle lpglimi? my petrol?
