Misfire in 407 vehicles
08.05.2020 14:53 # 1
turkuaz55
Hello, I have a 2.0 liter 407 diesel car, the car does not eat gas, so often it shifts, and when you go 100 km fast, you take your feet out of the gas and press it again. as printed. I got to the service, I did not have any problems on the computer, I changed the injectors, still doing the same. I wonder if you can help.
thanks
08.05.2020 14:53 # 2
MaximuS
I would say the diesel quality may be low, but you even replaced the injectors. I suppose you pay attention to the diesel you get, right? but still don't ignore this fuel situation ...
08.05.2020 14:53 # 3
tigerland
I did not use a diesel engine, but there was also a problem in this vehicle.
08.05.2020 14:53 # 4
actually, every diesel does not attack as soon as it presses on the gas, it will be activated with turbo power after 1 second. Could the catalyst be blocked?
08.05.2020 14:53 # 5
ozaannn
If it burns too much in its fuel, the catalyst is blocked, but the diesel car does not immediately absorb the gas, it should have been an average of 2 seconds, was it not before?
08.05.2020 14:53 # 6
a bit of possibility, but the dump valve mechanism inside the turbo may have been malfunctioning. ensures that the exhaust gas does not come out of a separate channel and get into the exhaust path when it comes out of the gas. This valve closes when the gas is pressed and the exhaust gas of the turbine is filled and the pressure is increased.
If there is no problem when the gas is pressed continuously, if this is done when the first time is pressed, this is the first thing that came to my mind.
08.05.2020 14:53 # 7
turkuaz55
Yes, I am paying attention to the diesel, but it is like a misfire. It is not like taking it in the night, so you cannot drive the car.
08.05.2020 14:53 # 8
turkuaz55
So this was not a problem, and if there was a catalyst obstruction, would that be misfire in the car?
08.05.2020 14:53 # 9
turkuaz55
So there is no such problem, when I say the problem of taking the gas, the pedal becomes idle.
if it is both catalyst and the server does not show the error in the service
08.05.2020 14:53 # 10
45ns021
same problem happened in my 1.6 1.6 car they called me gas sensor
