Misfire and stop when I run 307 in the morning
08.05.2020 14:56 # 1
dikmentr
Friends, 6 months ago, I had the auto gas in line with Romano. There was no problem. It works with gas in the morning.
when I run in the last days in the morning, it kicks continuously and stops running, and stops and stops, it starts to collect the idle in the bag, it does not stop, but it kicks it to the service and they said that the spark plug cleared the throttle and replaced the spark plugs .. I went to the roadside and shut it off, the problem is good, bad, they went to a service and connected a pc there, it gave me a low mixture error and after about 4 months ago I changed the manifold and oxygen sensor of the car and looked at the probe values.
It may be due to the oil coming in time.
dikment is 2010-10-30 11:39:00
08.05.2020 14:56 # 2
okanisilak
LPG calibration should be done again.
is probably caused by a poor mixing error.
08.05.2020 14:56 # 3
dikmentr
Poor mixture but when it works on gasoline it somehow ....
08.05.2020 14:56 # 4
dikmentr
Why does it cause poor mixing error on gas?
08.05.2020 14:56 # 5
pachito
greetings, the same problem was with me, the car seems to be silent, idle falls, then either stop or the engine was collecting itself, but & nbsp; When I went to LPG, this event disappeared & nbsp ;, & nbsp; I went to 2-3 places in Izmir & nbsp; all said something different, & nbsp; the latest & nbsp; my service & nbsp; it turns out that the pressure of the gas pump is pressing lower than normal, and it is made of it, and they put a zero pump for trial purposes, the problem disappeared, my advice is to take a look at the gas pump ...
08.05.2020 14:56 # 6
dikmentr
a master said this, but I went and said that there was no other service interest, the original service said that it would happen, but the institution might have fallen to the valves, but if the institution was in the valves, the problem would be in lpg. it may be or because the gasoline does not have a filter, the 307s may be in
clogging. Let's see.
08.05.2020 14:56 # 7
dikmentr
What is the price of the gas pump average
08.05.2020 14:56 # 8
dikmentr
what should I do with friends
08.05.2020 14:56 # 9
dbmaster
this is a problem in the lpg head press, killing the engine in the long run, get bigger problems
08.05.2020 14:56 # 10
oguzhan29
take it to the service, get a price
08.05.2020 14:56 # 11
dikmentr
Is the exact gas pump related?
08.05.2020 14:56 # 12
woswosist
I recommend you to go to a good master, it is very difficult to call it, but there are good masters of auto lpg and repair service in maltepe
08.05.2020 14:56 # 13
dikmentr
lpg has nothing to do with gas, this job lpg runs smoothly, it gives error when going on the road, I get poor mixture error in gasoline, I don't get lpg
08.05.2020 14:56 # 14
woswosist
I have my gasoline maintenance in my vehicle there.
08.05.2020 14:56 # 15
oguzhan29
friend has done a nice share, take it there and connect it to your sister computer and make it look
08.05.2020 14:56 # 16
pachito
The last time I asked, the price of the gas pump for 106 was around 300s, but I don't know how it is at 307, I hope this failure & nbsp; get it done as soon as possible ...
08.05.2020 14:56 # 17
dikmentr
FRIENDS GASOLINE pump from IND LPG DEDE DOING THE CAR IN vibrate exists today in the BENZ Me RUN DIRECT ROLANT the fall AGAIN RISES PEJEOT SERVICE the GOT would DED they SEE LET to GASOLINE SYSTEMS LPG they ATI LPG DE DED CARS FIRST BENZ in DOING LPG DE DO If LPG is RELATED BOSH GOT I LAMP SENSOR CAN BE
BUJU YAG I HAVE CHANGED THE OIL WHICH I DON'T FIND THE SPARK PLUG, WHICH I HAVE PROVIDED THE GAS BUTTERFLY AND THE PROBLEM NEEDS TO DO THE SAME GUINEA
08.05.2020 14:56 # 18
selfat8
friends have advised, see the authorized services do not understand the lpg business, I think
is a good advice with stronghold
08.05.2020 14:56 # 19
comondx
Isn't your problem like that? When the engine is cold, the vehicle is running on gasoline and the LPG system is activated, but when the engine is cold, you do not experience this problem when you do not switch to LPG. Doesn't this problem work? Do you study this.
