First of all hello everyone,
First, I gave the vehicle gas, then I set off and changed the 1st and 2nd gear at high speed. I tried to run it again and it did not work. After seeing the temperature exceeding 90, opening the bonnet and waiting for a while, I tried again and worked smoothly. Then, when I started it again, there was no problem, I started to change the gear at low speed and started to give the same gas again, this time did not stop. Idle idle, I waited for 2000 cycles and stopped. the brake pedal swelled excessively and when I run it repeatedly, there was no improvement in braking and idling. I pulled to the house with semi-gas to the house. (0.5 rpm increases as you press the gas, not only 3000 rpm. same problem continues in gas and gas)
Aciman 2019-11-13 06:56:32
