misfire and excess fuel |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 106 | |
| 08.05.2020 14:52 | # 1 |
| 08.05.2020 14:52 | # 2 |
Greetings! You have to go to the service. I had this problem too. When I bought the car, there was a sub-industry spark plug. After replacing the original 4 Peugeot spark plugs (20TL), the problem disappeared. Take off relaxed. |
| 08.05.2020 14:52 | # 3 |
I offer service and a complete detailed maintenance
| 08.05.2020 14:52 | # 4 |
indeed, it is very close.
| 08.05.2020 14:52 | # 5 |
[QUOTE = 60de106] good day I have 106 .14 quiksilver I just bought the car when it stops in the light, the cycle hand is falling off, it is self-winding on the road when driving in the city, and it burns a lot of gasoline and burns 500 lira. There is a problem with the engine, there was a similar problem with my old vehicle. I could travel 380 km with a warehouse. Bad at idle. Good engine master, Good maintenance |
| 08.05.2020 14:52 | # 6 |
oguzhan29 |
I'm pretty much burning on the show, go to a room and show him
| 08.05.2020 14:52 | # 7 |
GiTaRRa |
Check the gas setting. Replace spark plugs. Replace air filter. If the old auto bidet circuit may be stuck.
| 08.05.2020 14:52 | # 8 |
In addition to what the friends say (the maintenance is really important), the exhaust, the tire air and another important issue is where you get the fuel (reliable, a place where you constantly refuel).
| 08.05.2020 14:52 | # 9 |
landirenzo had the same problem in my old car, it was completely distracting when the air conditioner opened, while shaking, stapling, the car was opel di by the way
| 08.05.2020 14:52 | # 10 |
If I remember this vehicle wrong, 950 kg. and a 75 horsepower vehicle, both light and fast and fast, friends will know much better, but there are 2 reasons why the fuel is so high, either a maintenance-free vehicle (I mean maintenance-free misunderstanding routine vehicle maintenance) & nbsp; or you are using it too hard. is increasing its consumption.
| 08.05.2020 14:52 | # 11 |
In your vehicle, the complete throttle area will be manifold, etc., clean the spark plug & nbsp; or something. In addition, we can look at the catalytic converter. If too many km is not handled, it may be getting blocked.
| 08.05.2020 14:52 | # 12 |
Hah, cecoli came at the master, how are you bro?
| 08.05.2020 14:52 | # 13 |
Estagfurullah, I would like to thank you for my mastery & nbsp; By the way, I'm fine, how are you? & nbsp; also need to examine this friend's vehicle very well. there are so many things that will affect the fuel? & nbsp; comment & nbsp; difficult subject from that pain ... & nbsp; generally needs a good maintenance and control ... |
| 08.05.2020 14:52 | # 14 |
EK-6 |
Idle regulator problem.
| 08.05.2020 14:52 | # 15 |
I have been in the industry for a long time, rolenti knock sensor spark plug (in the original service) oil water antifreeze, I have done everything. The problem is now either in the sente setting or in the brain the industry has decided to be so high :) after the feast, the sentence setting and the brain will be looked after. thanks...
