Misfire
16.06.2020 09:10 # 1
Ebubekir
2006 model 1.4 gasoline sequential system lpg there is a lot of revolving clock in the car in the beginning, I had the throat valve maintenance fpn I changed the spark plug I changed the oxygen sensor I had the coils checked, then there was a very small fluctuation.
16.06.2020 10:05 # 2
Well, my teacher is doing this in gasoline, vehicle. air hoses etc. An old gasket may have been checked because the air filter container would draw too much air.
16.06.2020 10:07 # 3
Ebubekir
He does it both on gas and gasoline, master
16.06.2020 10:08 # 4
Ebubekir
If you don't start it first in the morning, it stops when the gas starts
16.06.2020 10:23 # 5
Then, first check the gas regulator (brain), if the membrane inside is torn, it causes LPG leakage to the intake manifold at the first start, and the vehicle runs late or stops because the gasoline LPG is mixed. Use it in gasoline for a certain period of time. Of course, before there is a small valve in the LPG tank, it will not come to the engine section of the gas valve, let's see if the same problems will continue.
16.06.2020 10:31 # 6
Ebubekir
I tried it for 20 days and when I bought the vehicle, I took it directly to the master, I had everything done, I had the gas settings, maintenance, everything checked, it said no problem.
16.06.2020 10:35 # 7
Ebubekir
He said, now the valves will be inserted, the upper cover will be checked, I did not want to get the car out.
16.06.2020 10:48 # 8
Ebubekir
Do you think I should put the valves on the top
16.06.2020 11:53 # 9
I think don't take it apart, keep away from the master who removes the top cover without performing a compression test. https://birlikotoservis.com/ take it here and close, many groups are satisfied
16.06.2020 12:15 # 10
Ebubekir
Eyw thank you very much, this is close to me, 15 minutes to me, you know my solid master
16.06.2020 14:31 # 11
Thank you. Well, there are a lot of people in facebook groups, they are satisfied they say solid master. Go tell me a viewpoint, let's see if you don't feel comfortable with it, you won't have it done by my teacher.
17.06.2020 10:30 # 12
demet55
I have a question, I became a member, I will send a message, I can't manage where I have to write my car is turning off the gas. Please help who knows they connected to the computer.
17.06.2020 14:22 # 13
[QUOTE = demet55] I have a question, I became a member, I can not send a message, I cannot write my car is turning off the gas. gasoline and lpg have the same problem?
