misfire
08.05.2020 15:26 # 1
helot
After using friends over 1000 km of gas yesterday, I made lpg adjustment again. Today I realized (yesterday) when he was working at idle, when he suddenly gasped, he made a whirling, after a while he sensed the gas, but when he gased slowly, there was no problem. Suddenly, I don't smell like I said gasing. There is no problem at home, why? In addition, it looks like it is very vague on gasoline, but I'm not sure and when I let out gas and gas, like cat rally cars, cat cat sound sounds normal from exhaust?
08.05.2020 15:26 # 2
tilbe307
I realized it today. I have it in my vehicle. When it is loaded on the gas, it is like a proposal first. as if squeezing the throat of the car. It takes late to accelerate to gas.
08.05.2020 15:26 # 3
kaan__
get a lpg clip again or return the lpg interface to the original fabrija settings ... you will also benefit from changing the spark plugs
08.05.2020 15:26 # 4
ALX
In general, the enrichment of the Pejos is very sudden, the gas time increases from 2 ms directly to 10ms and above. The LPG system cannot detect it immediately if it is set incorrectly. I also had it, I reduced the enrichment at acceleration a little and made the gas pressure at 1.15 from 1.0 bar. Like ferrari right now Embarrassed ...
08.05.2020 15:26 # 5
ismail ozdemir
the same problem is in my mind, the spark plugs were changed, the butterfly was cleared, but it was flat, but it still does when I give the moment gas in the park, but the draft of the vehicle has improved.
08.05.2020 15:26 # 6
[QUOTE = beyazzzzz] I have the same problem with me, the spark plugs have changed, the butterfly has been cleared, but it is still in the park when I gas it, but the car's pull has improved.
Do not play with gas pressure without connecting the information. you cannot change the setting without seeing the pressure. In addition, such a problem may not be solved directly with the low or high pressure. At this point, pressure does not mean everything. As the pressure increases, the amount of gas entering into it increases. hence the spray can be changed.
08.05.2020 15:26 # 7
ismail ozdemir
I understand, thank you. There is not enough problem to make a problem. I just had a strange and slight shaking and drowning. ??
08.05.2020 15:26 # 8
[QUOTE = beyazzzzz] I understand, thank you, there is not much trouble to make a problem. I just have a strange and slight shaking and drowning when I give sudden throttle. When I switch to position, it leaves a shake ???
many of them do this tremor in gas?
08.05.2020 15:26 # 9
helot
Today, the problem is not improved, I did not do it. strange: S
08.05.2020 15:26 # 10
well then nice :)) something happened instantly in the back ... it was temporary
08.05.2020 15:26 # 11
helot
may be Cem. I was asleep at night thinking :)
08.05.2020 15:26 # 12
ismail ozdemir
does not
08.05.2020 15:26 # 13
ALX
[QUOTE = CeCoLi] [QUOTE = beyazzzzz] have the same problem with me, the spark plugs changed the butterfly was cleared, but it was flat, but it still does the moment when I gas in the park, but the drawer of the vehicle was flat.
I agree, if you do not understand from the LPG setting, do not get infected. My gas time was high, I increased the pressure to lower it, began to spray the required amount of gas in a shorter time, the problem of misfire and late degassing disappeared.
08.05.2020 15:26 # 14
Platinium
The flickering problem was doing to me from time to time, and the engine was working for a long time, it was very annoying, especially when it was idle, it was excessive, the spark plugs and the ignition coil changed, the construction doesn't do it again. I don't have LPG by the way.
Platinium 2011-05-19 22:10:32
08.05.2020 15:26 # 15
[QUOTE = Platinium] The flickering problem was doing to me from time to time, and the engine was running for a long time, it was very frustrating, especially when it was idle, it was very excessive spark plugs and the ignition coil changed, it doesn't get built again.
Have you been overnight then. the spark plug and the bob are important parts at such points. Sometimes, it seems that the bob is working, it can cause trouble because it cannot produce enough current.
08.05.2020 15:26 # 16
Platinium
Tklr maintenance was done, construction fuel falls a little, even if a little bit of misfire, the fuel was affected, I did not have a full account, but I was burning 50kgs. Platinium 2011-05-19 23:14:39
08.05.2020 15:26 # 17
ALX
Once I forgot the headlights on, the battery is dead. I started the vehicle with reinforcement and did not use much. I guess the battery is not fully charged. The next day it rained heavily, as soon as I got on, I turned on all the electrical appliances, headlights, fog, wipers etc. I think the dynamo got wet, the car didn't eat gas like you said and started kicking, so the weak battery and wet dynamo can also misfire. When the engine warmed up and the fan turned on, he soon regained himself, the dynamo has dried up. Here is such a story Gülme .
08.05.2020 15:26 # 18
efeli
the problem of stopping after kicking and drowning to gas pressure is called "kebbek".
