Mirror troubles
08.05.2020 18:01 # 1
cansytnn
After a very bad incident I experienced today, I understood that the original 307 mirror, which shows the short distance, is not too small. Can I put it in Ankara to tell places to help?
08.05.2020 18:01 # 2
kuscu38
I KNOW THAT THE ORIGINAL MIRRORS ARE AFTER TESTED TEST! IF YOU WANT TO USE OVER, I WILL USE THE F1 MIRRORS BUT YOURS ARE ELECTRIC.
08.05.2020 18:01 # 3
qqyyxx
The viewing angles of the 307 are very good. You have not adjusted the mirror including the side mirrors.
08.05.2020 18:01 # 4
Serkan
Get well, I don't think you will have a lot of trouble if you adjust the mirror well, adjust the rear fender of the vehicle to see it very lightly.
08.05.2020 18:01 # 5
SoSRiQuO
Is there a possibility that the mirror might not be original? There is a comfortable viewing angle in the originals, but if the vehicle on the right has passed the right rear window a little and there is a distance of more than 1 and a half meters between you, it may be in the blind spot.
08.05.2020 18:01 # 6
error
My teacher, we call it a blind spot. This problem is present even in the most advanced vehicles. There is a blind spot sensor for this problem. There are two solutions for this in our vehicles, but our vehicles have two solutions .
08.05.2020 18:01 # 7
Can Oksuz
I had the same difficulty that you mentioned. We came to Ankara for a 3-day job with your friend's 307s. it was a right rearview mirror that I did not like on the car. By adjusting the fender not to show it, I slightly exceeded it. Does anyone have the information why the end part is not made more wide angle like the left mirror?
The other thing I didn't like was that the clutch was a little stiff. Other than that, I liked the tool. :)
08.05.2020 18:01 # 8
Can Oksuz
08.05.2020 18:01 # 9
korkusuz202
It is not the exterior mirror.
CLICK HERE TO SEE THE PRODUCT
08.05.2020 18:01 # 10
ersin025
I have to set me on the road, not the mirror in the parks.
08.05.2020 18:01 # 11
cansytnn
mirrors electric right rearview is a problematic one, either it seems small to me or the tip of the rear fender is visible so that my really small right mirror setting is hard to see the door handle
The incident was like this: I was going to pass from the left lane to the middle lane, I gave the signal, but when I said the wedding convoy was moving from the far right lane, I guess I did not notice the broadway next to me, I think I was approaching the left right, then as soon as I saw the bumper in the mirror, I left the steering wheel to the left. I broke it and the car started to slide like a car from behind. I picked up the car when I said left right left right.
08.05.2020 18:01 # 12
blinddark
When I first bought the 307, the mirror angle of view was small, so I was more comfortable with the mirrors in my previous car (98 vectra) but later I got used to normal traffic or parking in Ankara. I try to use the mirror by moving, 307 mirrors are insufficient for me ...
