Mirror problem |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 508 | |
| 08.05.2020 20:37 | # 1 |
| 08.05.2020 20:37 | # 2 |
ggitaristt |
Could your insurance be burned? Otherwise, the mechanism may be stuck. Edit: He may have tried to close with his hand and got through the gear. |
| 08.05.2020 20:37 | # 3 |
sonerkyl |
I think if it doesn't work, bro.
| 08.05.2020 20:37 | # 4 |
High probability insurance. All functions do not go unless you force-break and break the cable in between. If it closes manually, maybe the folds are just corts. Check your insurance or get it
| 08.05.2020 20:37 | # 5 |
Ozgur3310 |
First of all, your vehicle is good. I have the same model vehicle. The day I bought the washer opened and closed the right mirror by hand. Then my right mirror did not shut off electrically. But all the other features of the mirror were working. As a result, there was a plastic gear in the mirror that the engine was turning. It was broken. Unfortunately, I changed the mirror. both of them? And try this: while the vehicle is running, press and hold the mirror fold button on the door handle for 5 seconds.
| 08.05.2020 20:37 | # 6 |
Thank you for your interest, I did what you said, unfortunately, I think there is an insurance problem, but how do I get mirror insurance. The mirrors don't even adjust, it's not just a problem. I have to manually close the side on the road. I was available and couldn't go to the electrician. How can I change which one can I know and how.
| 08.05.2020 20:37 | # 7 |
sonerkyl |
[QUOTE = Omeroztemur] Thank you for your attention, I did what you said, unfortunately, I think there is an insurance problem but how do I get mirror insurance. The mirrors don't even adjust, it's not just a problem. I have to manually close the side on the road. I was available and couldn't go to the electrician. How can I change which one can I know and how the insurance is. [/ QUOTE] If your vehicle has a user manual, my writer is there. otherwise you can look at this link. |
| 08.05.2020 20:37 | # 8 |
hello again, The mirror problem of the vehicle corrected itself when I got up one morning. Interestingly, when the problem happens, it is not only the folding of the mirrors, but also the adjustment that becomes passive. I think it's an electrical problem.
| 08.05.2020 20:37 | # 9 |
sonerkyl |
then there may be a situation such as non-contact in the cables. teacher
| 08.05.2020 20:37 | # 10 |
[QUOTE = Omeroztemur] hello again, The mirror problem of the vehicle corrected itself when I got up one morning. Interestingly, when the problem happens, it is not only the folding of the mirrors, but also the adjustment that becomes passive. I think it's an electrical problem. [/ QUOTE] They know what the hell they did. They read the lives of 407 people you knew 5 years ago. I take my 20 minutes and wash it myself. I do not give it to anyone after what I heard. I see it on the way, the guys jump from the bumps to the jump like wrc.
| 08.05.2020 20:37 | # 11 |
The left rearview mirror of my 5008 car opens completely, can you illuminate about the solution |
| 08.05.2020 20:37 | # 12 |
I don't know why it doesn't work because I just bought the car. Think about it from insurance.
| 06.02.2026 14:52 | # 13 |
Hi friends, I have a 2009 model 308 and I changed the left window lifting buttons on the front side. [Image of the image shows the integrity of the car] data-cf-beacon="{"version":"2024.11.0","token":"11ac6a036a5c4b83a3c20a30a3bc3ba2","r":1,"server_timing":{"name":{"cfCacheStatus":true,"cfEdge":true,"cfExtPri":true,"cfL4":true,"cfOrigin":true,"cfSpeedBrain":true},"location_startswith":null}}" crossorigin="anonymous">The automatic closing of the left mirror is not working. It doesn't close the mirrors manually. I'm putting the old button back on, but it doesn't work. The mirrors close automatically, but the new one doesn't close the left mirror automatically. Is there anyone who has experienced this? I bought the window switch from Temud, all other functions work. Has anyone experienced this or has any information about a solution?
