Mirror link and Android auto connection problem
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2009-2015)
08.05.2020 21:19 # 1
mozenrah
Hello there. I have the Honor 8x phone. But my peugeot 3008 brand 2018 model car cannot connect this phone. Although my car has mirror link and Android auto feature, it only connects via Bluetooth. I would be glad if you could help. When I talked to Peugeot, they told me to download applications from stores with trial and error method that Honor 8x is not compatible with the system they use. But the result is frustrated.
08.05.2020 21:19 # 2
Unfortunately, as the service says, you cannot provide connection with the Honor series.
08.05.2020 21:19 # 3
mozenrah_59
I contacted several authorized services, they said it was impossible to connect, then I contacted Pejo Headquarters , they directed me to an authorized service in Istanbul. Now I can use all the features of my phone on the screen of the car. Thanks to everyone who contributed.
08.05.2020 21:19 # 4
hasan16
Hello, I wonder which service you contacted? I bought a new vehicle. I can not connect.
08.05.2020 21:19 # 5
ibesler
greetings, can you share the web address and the name of the program
08.05.2020 21:19 # 6
Ekrem07
lutfwn problem by connecting to which site you would like to share your solution .. Site name and any other applications you use
08.05.2020 21:19 # 7
mualgl
Hello there,
Will you share the application information you installed and the service information you talked about?
I cannot connect my 2019 2008 gtline a note8 device.
08.05.2020 21:19 # 8
Omer87
Hi
You should try this application, it's on google play but i can see
I sent the apk, I am using the mirorling feature with this application
Maybe it will help
08.05.2020 21:19 # 9
mualgl
Hello there,
First of all, thank you for your interest. I did not try the application you sent, but I downloaded the apk of an application called Android auto and it worked directly without plugging it.
08.05.2020 21:19 # 10
bsencan
Hello there.
Not 3008 but I'm a 2008 user :) I had the same problem with my car. Download android androidauto.apk file before any of the sites that come out when you type android auto apk and search for uncle google. Then transfer this file to your phone via usb cable or bluetooth. then, if it is not activated, activate USB ERROR option in the developer options on your phone. After that, also enable the option to allow the installation of applications from unknown sources, usually in security options, in the settings. Install the application. Connect the phone to the 3008 USB cable. The android auto application will already run automatically. but if it doesn't work, launch the app manually.
These described works on most phones using android operating system.
respects.
08.05.2020 21:19 # 11
akinag
Hello friends. I have been trying to install it in my new vehicle for 3 weeks.
I have a Samsung A50, whatever I did. Yesterday when I installed the latest version of android auto on my friend's Samsung A5 phone and connected it to the car without doing anything else, it worked directly. As far as I understand, Android 9 (PİE) version is working, but the friend has 8 versions.
For your information, don't worry, I guess those who can't run 9 and 10 versions
13.11.2020 16:43 # 12
Clayksis
You said it might be logical, but on top of that, it is necessary to think about the type of multimedia system you use, I am using the a50.
11.02.2021 21:59 # 13
mercan77
Hello everyone, I'm a 2020 model 2008 user. I also could not use android auto. Even when I took it to the service for 15000 control, they could not help either. They put the blame on android saying it happened after the updates. I found the solution in a YouTube video I watched. I bought a Soltech brand type c-usb cable and as soon as I plugged it in, android auto worked. My phone is note 10 lite. I bought the Soltech cable from here
18.02.2021 00:20 # 14
Ferat
Mrb I also have a Xiaomi phone, the original cable does not recognize the 3008 in my vehicle.
20.02.2021 21:43 # 15
ulas55
[QUOTE = mercan77] Hello everyone, I'm a 2020 model 2008 user. I could not use android auto either. Even when I took it to the service for 15000 control, they could not help either. They said it happened after the updates and put the blame on the android. I found the solution in a YouTube video I watched. I bought a Soltech brand type c-usb cable and as soon as I plugged it in, android auto worked. My phone is note 10 lite. I bought the Soltech cable from here [/ QUOTE]
mrb brother, could you please share the link of the cable, let's buy it and try it.
08.03.2021 01:05 # 16
stat
Hello, I got 5008 last week. The original software of the vehicle could not connect with my Note 10 Plus phone. The connection was constantly disconnected and trying to connect again. I installed the MyPeugeot application on my phone and registered. Then the app notified me that there are car software and Navigation updates and how I can setup. I did both the car software and the Navigation updates as you have a problem. All updates took an average of 1 hour.
After the vehicle software update, I connected my Android 11 phone with a cable without installing any additional software. Mirror Link licensed applications were only displayed on the eraç screen.
Come easy
25.08.2021 15:50 # 17
mystery80
With a quality cable, you can make your android auto connection without the need for any application. The Android version of your phone matters. My version is 10.0 and it works fine. Bluetooth is on, plug in your cable and wait for the detection time. It takes about 30 seconds max. You may say why should I use Android Auto? You can use navigation and google services with voice command. So you can't use it other than Android auto's applications. It's not an indispensable thing.
