mirror covers
08.05.2020 15:02 # 1
Ego_Ist
Hello friends,
replacing the rearview mirrors of the car because the adjustment buttons are faulty, the new mirrors' covers are not painted ... do I have to sand them with zero water sandpaper and then paint them with spray paint without removing them from the vehicle ??? Does it hold paint ?? Or should it be removed, putted and painted? frankly, the disassembly is not much for me ... if there is a way to disassemble it will be much better..thanks ..
08.05.2020 15:02 # 2
Ozgur
I'm definitely wondering about that.
08.05.2020 15:02 # 3
xMEGANx
What are you doing? If you love this god, whatever you do, we can not do it ourselves.
08.05.2020 15:02 # 4
Ego_Ist
This is not the answer to my question, I do not want a new idea, my friend, I know how to go to the service ... You can go all the way and do whatever it takes to make it on the left and right ... you can do it yourself ... light bulb exploded go electrician calls then the same logic is yours .....
08.05.2020 15:02 # 5
Ozgur
You get from the worst publisher if you can't do the cover as you like.
I think it would be more enjoyable to try and do it yourself. Happiness when you do is invaluable. Gülme
It did not happen. It is the worst case.
Does anyone understand this paint job?
08.05.2020 15:02 # 6
muratgulen07
instead of paint ... glossy black or vehicle color..childer will be cheaper and easier than to paint ...
08.05.2020 15:02 # 7
I think it shouldn't be hard to put the cover on. I think if you sting it, you will get better heat ...
In addition, paint may not hold well on some plastic surfaces. There is a paste-like material on top of the bumpers from that pain. they are painted on it
coating in another solution it makes sense ...
08.05.2020 15:02 # 8
Ego_Ist
thanks friends..
08.05.2020 15:02 # 9
Ozgur
I think it only holds the coating for the mirror caps.
But they said it would not be when I asked for his plot.
08.05.2020 15:02 # 10
erdal
If you want you can cover carbon foil, I think it looks nice. what color is your vehicle
08.05.2020 15:02 # 11
individual
old caps are not wearing new ones?
307 ni covers are changing very easily.
edit:
You said I don't want to disassemble.
i got it wrong
Gülme
individual 2011-01-13 21:17:14
08.05.2020 15:02 # 12
Psh
Well, I changed the mirror, believe me, the worst solution is to remove the cover from the old mirror and attach it to the new mirror. There is neither color shortage nor anything else. Very easy to disassemble. Then, if you want the unpainted cover on your hand, you can paint it yourself.
