Miracles of Silicone Spray ..
08.05.2020 20:14 # 1
Peugeot35
I had a problem on the left windshield before, and I had overcome the problem with the miracle of silicone spray, which means I was talking about a very nice and useful subject as a result of my research on silicone spray on youtube.
See how the pulling seat belt pulls.
and there are many more miracles, it is useful in your research.
08.05.2020 20:14 # 2
CVT
Thank you for the information
08.05.2020 20:14 # 3
Oktkor
I used it before, I wrote it here. It speeds up seriously. Now the sound comes from the seat belt column. With the help of a small pipette, I think about squeezing the column before it goes out.
08.05.2020 20:14 # 4
yigit_dark
After a while, it gets old. In my opinion, to reach the mechanism, to clean the dust, etc., to make this application. I see this as a temporary solution.
08.05.2020 20:14 # 5
ggitaristt
I reached the mechanism but I couldn't do anything .. It still takes 1 minute to collect ..
@ Peugeot35 nice sharing ..
08.05.2020 20:14 # 6
BLACK LION
I have also been working very well for almost a year. If you squeeze between plastics that touch each other, it will cut the trim sounds.
BLACK LION 2017-03-11 09:53:13
08.05.2020 20:14 # 7
OguzhanKucuk61
Is there a particular brand recommended? Friends using?
Whatever my seat belt is, it does not pull as it is trapezoid in its seat.
Yesterday door lock, after cleaning the dust soil on the bellow with lining spray, I believed in the miracle of spray :)))
08.05.2020 20:14 # 8
Oktkor
I think mine is würth.
If you insert a screwdriver between the belt buckle of Oğuzhan and turn it a little bit, can't you flex the little bit and turn the belt buckle and save it?
08.05.2020 20:14 # 9
OguzhanKucuk61
[QUOTE = Oktkor] I think mine is würth.
If you insert a screwdriver between the belt buckle of Oğuzhan and turn it a little bit, can't you flex the little bit and turn the belt buckle and save it? [/ QUOTE]
I did not emphasize much. But I tried and got stuck while turning. Maybe I will save if I try but I feel a little bit hurt.
08.05.2020 20:14 # 10
Oktkor
[QUOTE = OguzhanKucuk61] [QUOTE = Oktkor] Mine seems würth.
I did not emphasize much. But I tried and got stuck while turning. Maybe I will save if I try but I feel a little bit hurt. [/ QUOTE]
I understand.
By the way, I lubricated the doors with würth spray oil. His squeak increased after lubricating. :) I guess I hope it will cut as you eat.
08.05.2020 20:14 # 11
OguzhanKucuk61
Yesterday, we applied Balata spray to the locking mechanisms, which have tied the dust, to the bellows parts inside the door.
Immediately afterwards, the left rear door started to be installed. We supplemented with liquid grease. It was pretty good. Use liquid or solid grease, I think, teacher
08.05.2020 20:14 # 12
OguzhanKucuk61
In fact, I think it may be good to use solids in terms of not flowing.
08.05.2020 20:14 # 13
Oktkor
Reviews of it were like that. After a while, it was said that it hardened and lubricated the place where it was bored. Let's see a few days :)
08.05.2020 20:14 # 14
Oktkor
[QUOTE = Oktkor] Comments of that were also like that. After a while, it was said that it hardened and lubricated the place where it was bored. Let's see a few days :) [/ QUOTE]
No need for a few days. No click :)
08.05.2020 20:14 # 15
Peugeot35
friends serve to clean the lining of the lining spray, it is degreasing, there is a thinner or something, I would not recommend tightening it to the wicks.
I have no doubts as the silicone spray will show permanence after applying it to both the belt and the mechanism. Applying to the belt is of course a temporary solution. but after cleaning the mechanism, the problem will be solved radically since neither the sun nor anything will see it.
Really silicone spray miracles are also very much like crushing door wickes, extinguishing, cracking etc. it protects from everything that may happen, but it is necessary to carry out this operation in the summer. Smile
08.05.2020 20:14 # 16
OguzhanKucuk61
[QUOTE = Oktkor] [QUOTE = Oktkor] Comments of that were also like that. After a while, it was said that it hardened and lubricated the place where it was bored. Let's see a few days :) [/ QUOTE]
No need for a few days. No click :) [/ QUOTE]
Maallah, brother :)) it was good
08.05.2020 20:14 # 17
OguzhanKucuk61
[QUOTE = Peugeot35] friends serve to clean the lining of the lining spray, degreasing, there is thinner or something, I would not recommend tightening it to the wicks.
Right teacher. It is true that it contains thinner, but I do not think it will corrode and damage due to this cellulosic synthetic difference. There is a small amount. However, it should not be used in plastic parts.
Are there any special brands you use for silicone spray?
08.05.2020 20:14 # 18
Oktkor
I squeezed into the suppositories, I was spraying Slikon, but I did not see a difference in the sound. There is a benefit.
08.05.2020 20:14 # 19
Peugeot35
[QUOTE = OguzhanKucuk61] [QUOTE = Peugeot35] friends serve to clean the lining of the lining, it is degreasing.
Are there any special brands you use for silicone spray? [/ QUOTE]
I think it would be good if I buy it from Netherlands.
LINK: http://urun.n11.com/ic-temizlik-ve-koruma/motip-silicon-spreyi-400ml-made-in-holland-P99736213?cid=604001&gclid=CLHMhrHnztICFYY_GwodBBQK2g&gclsrc=aw.dsrc
It is more accurate to apply the lone spray to metal parts that fade the color of the plastic. no lubrication feature. Of course everyone has a different opinion.
Peugeot35 2017-03-11 18:59:54
08.05.2020 20:14 # 20
Peugeot35
[QUOTE = Oktkor] I squeezed into the suppositories, I sprayed Slikon, but so oh myself I did not see any difference in sound. There is a benefit. [/ QUOTE]
I can't say anything about sound cutting, but its lubricant is very good. It is a maintenance kit so that the wicks are not deformed. let me say you use the wick Smile
Page : / 2
