minimum temperature control and liquid cooling
08.05.2020 15:03 # 1
snak_ee
This malfunction lamp lights up 3 times when the vehicle starts up What is the solution with the stop lamp What is the solution 206 the vehicle is diesel Wall
08.05.2020 15:03 # 2
sercinho
If the vehicle is normal to see the engine water level, there may be a problem with the sensor.
08.05.2020 15:03 # 3
snak_ee
http://public.servicebox.peugeot.com/ddb/code/index_tr_tr.htm
Warning light 17 ...
08.05.2020 15:03 # 4
snak_ee
I sent it wrong sorry
08.05.2020 15:03 # 5
snak_ee
http://i56.tinypic.com/2rdesk9.jpg
08.05.2020 15:03 # 6
snak_ee
17. warning here
08.05.2020 15:03 # 7
snak_ee
The car is not overheating. I don't think it's a problem.
08.05.2020 15:03 # 8
sercinho
Friends who use diesel can help better
08.05.2020 15:03 # 9
ali oncu
If there is water shortage, the sign should appear on the right side, but it is good to look at it. Also check your oil.
08.05.2020 15:03 # 10
snak_ee
I added water half a liter, I hope the problem is because I will check it, but there is no crack in the pipes.
08.05.2020 15:03 # 11
you have to follow the water drop. If there is a shortage, you need to find and solve it ...
08.05.2020 15:03 # 12
GokhaN
mine is sometimes blinking. When starting the car. My sensor is broken. It may be corrupt in you. If there is no reduction, it is not a very urgent problem.
08.05.2020 15:03 # 13
ali oncu
you have to be careful and follow
