milk spilled help
08.05.2020 19:03 # 1
jackal67
Cry friends 2014 partner tepee left side underarm hollow poured 1lt milk on the floor, we removed the seat, removed the floor, did not go underneath from the internet as much as I searched from the internet, they said pour carbonate now how are you waiting for your help?
08.05.2020 19:03 # 2
jackal67
Meanwhile the car started to smell slightly, please help
08.05.2020 19:03 # 3
riderzist
Two months ago, his uncle came to his son and changed the interior flooring completely.: S could not get into the car .
08.05.2020 19:03 # 4
PARADOSK3327
brothers we put in the stove charcoal
08.05.2020 19:03 # 5
Alicilik
Well, we sold the car because of it.
1 milk
2 bodies
These scents don't go away. use carbonated products. Baking soda is a beautiful odor absorber. Wipe it beautifully with asprin. If it continues, replace the carpet.
08.05.2020 19:03 # 6
jackal67
Thanks a lot yesterday carbonate, I put a little water on my tissue, let's see, there is no odor, I will wipe it off with vinegar water today, my paradox friend will not put the command just there.
08.05.2020 19:03 # 7
PARADOSK3327
Brother I wrote the stove charcoal in my first comment was wrong, it will be kebab coal.
08.05.2020 19:03 # 8
KILIC
they used to use kebab coal and smell in their refrigerators.
08.05.2020 19:03 # 9
jackal67
If he doesn't have a mankal command, does he have any other type?
08.05.2020 19:03 # 10
PARADOSK3327
yes charcoal
08.05.2020 19:03 # 11
jackal67
Thank you brother, I am putting it right now.
08.05.2020 19:03 # 12
PARADOSK3327
Come on, it doesn't take long to throw it away and it takes a long time, and as I said, change the diary places to dry
08.05.2020 19:03 # 13
serdaralisan
brother 3M AND WÜRTH E OF CLEANING SUPPLIES HAVE FLOOR FOR FROM THEM AL 1 LITER WATER IS A COVER FLA put lather're wiping SCENT GOES PLUS CLEAR you PLACES NEW LIKE GOING AND DRUGS EXPENSIVE BUT GREAT CARPET CLEANING FACTORY HAVE HOMES SEAT WASHING COMING they ONLARD career SUPPLY You CAN I bought 5 pounds WURT CARPET SEAT AND WOOL SURFACE CLEANING FROM THE CARPET WAS COMING TO WASH THE SEATS IN A HOME AND FRAGRANT WAS NOT FLANGE
08.05.2020 19:03 # 14
jackal67
thanks bro, let me investigate a lot for your help
08.05.2020 19:03 # 15
samet206
The smell of milk is bad, get well soon ...
08.05.2020 19:03 # 16
Efe-Pojo
One of your friends said würth, but be warned, I used different würth products. they are both expensive and they don't benefit at all, it seems to me as the biggest counterfeiting company in the world.
08.05.2020 19:03 # 17
okan0665
buttermilk was spilled on the back seat and carpet, now there are no artifacts. I cleaned it as follows:
1) I waited until it dried. during this time it is necessary to withstand the smell. After it was completely dry, I cleaned it with a brush. I vacuumed the dried buttermilk pieces with a vacuum cleaner.
2) I wiped it thoroughly with plenty of sparkling water with intense detergent. The sofa and the carpet got very wet, and when pressed by hand, the white foam will come out. then I pulled it with a vacuum cleaner. so I got the excess foam and water.
3) the most difficult part is this part. I wiped the same place with water this time. you may need to change the water several times at this stage. because it foams as you delete it. It is also necessary to wipe until the foam remains very little.
4) I vacuumed both the carpet and the seat, which were thoroughly wet with a vacuum cleaner. the more you can shoot, the better. then you prevent him from vomiting.
5) This time I wiped the excess water with a dry cloth so that I will get the remaining moisture. I left the windows open for one or two nights to dry completely. transaction ok :)
