Military service is over ....
08.05.2020 15:03 # 1
I have been a soldier since August. I am so thankful. I had my loved ones and my car. They said that when I left, the battery was disconnected from the pole, and the radio could not work when I arrived. I removed the pole head. My display has broken crystals exploded so I can't see the information.) So what I want to ask is there is a problem because I disassembled the battery terminal, but what? What do I have to do? 307
the laedr 2011-01-21 16:52:46
08.05.2020 15:03 # 2
So was the screen broken now or was there any earlier?
Does the vehicle work?
You had to carry out water steps when connecting.
1 Close all doors, just open the window of the driver fully.
2 Remove the key, if fitted.
3 Connect the battery. Do not open the doors calmly.
Wait for 4 10 seconds.
5 Extend the headlights by reaching out from the open window. You will hear a voice called "Bong."
6 Then start the vehicle and check all the functions.
Koliva 2011-01-21 17:02:39
08.05.2020 15:03 # 3
[QUOTE = koliva] So was the screen broken now or did it exist before?
The screen is broken for 1 year, friend.
08.05.2020 15:03 # 4
Teacher, the password of the radio writes on the information wallet that came with the vehicle.
08.05.2020 15:03 # 5
Now the information is actually missing. When I ask for a radio code:
1. As I said, you can find the code on the wallet that came with the tool.
2. If you cannot find it, I think there are programs on the internet where you can find the code based on the serial number.
3. It didn't happen either, you would go to the service or a special place that did it. The laptop's radio number is recorded in the radio's EEPROM in the vehicle's BSI.
The security number is written on the radio for security purposes. As you remove the battery, this information is deleted from the radio over time. When you start your car, it is compared with the chassis number in BSI on the radio. Because it is faint, it gives an error and the radio does not work.
Koliva 2011-01-21 17:14:29
08.05.2020 15:03 # 6
If you can't even find it, try the presentation and don't go to the service:
Let's say the last 4 digits of the serial number are 3512.
Starting from the left, you add 1 2 3 4 to each digit. So say:
3 + 1 = 4
5 + 2 = 7
1 + 3 = 4
2 + 4 = 6
If these output numbers are greater than 6, you subtract from 6. Because there are up to 6 numbers on the radio. So it is 7-6 = 1. So your radio code is 4146.
This method has been tried and running. I hope it works for you too. If you try too much and see ----- on the screen, remove the fuse of the radio and fix it :)
Koliva 2011-01-21 17:28:33
08.05.2020 15:03 # 7
Come on, brother.
08.05.2020 15:03 # 8
[QUOTE = koliva] If you can't even find it, try the presentation and don't go to the service.
3 + 1 = 4
5 + 2 = 7
1 + 3 = 4
2 + 4 = 6
I was looking for this information, God bless you.
08.05.2020 15:03 # 9
[QUOTE = mstfkrl] [QUOTE = koliva] If you can't find it, try the presentation and don't go to the service:
3 + 1 = 4
5 + 2 = 7
1 + 3 = 4
2 + 4 = 6
I tried my teacher, but he no longer wants the password on the device
screen 4 says ERROR.
I removed the model 22rc200 / 65 from the Philips 306.
08.05.2020 15:03 # 10
[QUOTE = mstfkrl] [QUOTE = mstfkrl] [QUOTE = koliva] If you can't find it, try the presentation, don't go to the service:
3 + 1 = 4
5 + 2 = 7
1 + 3 = 4
2 + 4 = 6
This error usually disappears by itself when the radio is on for 10 minutes. You keep the radio a bit. It did not need to reset. I have a method in reset Sırıtma
Koliva 2011-01-21 20:53:31
08.05.2020 15:03 # 11
I wish good luck, welcome back
