Mileage-Speed Indicator Problem
08.05.2020 15:05 # 1
fahrikem
When I run 206 today, the mileage speed indicator normally came to 10, it was stuck, there is no problem in other indicators, then it started to show the speed of the car after 3 4 minutes.
08.05.2020 15:05 # 2
klemann
these days cold people are getting mixed up in their cars like us
08.05.2020 15:05 # 3
voodoo
It is one of the 206 chronic malfunctions, I have this one too, brother ...
08.05.2020 15:05 # 4
Yes, it is a chronic malfunction. It usually does due to the contamination of its sensor. It goes away when it is cleaned.
The speed sensor either reads data from the flywheel or from the alternator. I don't know which one is in your vehicle. Usually it is 10mm bolt.
Koliva 2011-02-11 20:55:02
08.05.2020 15:05 # 5
ALX
I own a 106XS, and I have a mileage problem. According to his head, he gets stuck between 80-110. Where is the speed sensor in the 106? Can it be cleaned?
08.05.2020 15:05 # 6
[QUOTE = ALX] I have 106XS, I have a mileage problem. According to his head, he gets stuck between 80-110. Where is the speed sensor in the 106? Can it be cleaned? [/ QUOTE]
I'm not sure if your problem is sensorend. If you want to try, lift the vehicle, lie underneath and look behind the engine and behind the gearbox. the speed sensor is connected to the gearbox and is a white unit and cables enter. As I said, it has a 10 mm bolt.
Formal:
Koliva 2011-02-12 13:03:28
08.05.2020 15:05 # 7
ALX
Hmm, it wasn't easy to reach. We can only look with my master. Thanks for information...
08.05.2020 15:05 # 8
ekinoks44
I have 206 too, and the km counter sometimes stays at 0, never plays. They connected the electronic part to the device, they said no problem. I did not try too hard, but it is annoying to see the speedometer at 0. I hope we find a solution.
