Method to Relieve Gear Shifts
08.05.2020 17:41 # 1
samet206
Hello friends 206 gear shifts in my car is a little annoying, I was wondering what I know tells me to remove the gear gaiter and lubricate the bottom with grease to relieve the gears, I do not want to have a method like this. .
samet206 2013-06-12 23:41:10
08.05.2020 17:41 # 2
error
I do not think that lubrication will be useful because it has a spherical oval slot made of hard pilastic in that part, it touches the pilastic pilastic.
08.05.2020 17:41 # 3
I don't think gear shifts will be relieved when oil is applied there.
08.05.2020 17:41 # 4
samet206
Thanks for the answers, but there should be a meaning of the oil in that part.
08.05.2020 17:41 # 5
cocomo
he is my work age brother. these are chronic bony gears ... I don't think it will improve.
08.05.2020 17:41 # 6
emre_akdag
I guess isn't it chronic? the same thing happened with me. Especially when throwing from 2 to 3 or shooting from 4 to 3, there is a crumbling sound. sometimes it seldom does in other gear shifts.
08.05.2020 17:41 # 7
rolandgarros
Even if you do, the transmission will be slightly flawed after the inspection for oil leaks. LOL
08.05.2020 17:41 # 8
Thomassee
On the contrary, I like the bony transition Cool
08.05.2020 17:41 # 9
Aziz
I roll it when I roll, like chicken breaks wings, heheyyt, the best thing is: D
08.05.2020 17:41 # 10
ondercan
Shift gears in 206s.
Good luck with.
08.05.2020 17:41 # 11
samet206
Thanks, friends, if I think for answers, psychological relaxation would be much better if it did not advocate that it did work.Also for your rich advice, I researched a little about it, when I changed this oil, it would reveal all the problems, so some of the servicemen would have changed the manual gearbox in order not to take this responsibility. In fact, there are people who do not throw old oil and put new oil, and when there are crows in the gearbox, there are those who put the old oil again.
samet206 2013-06-14 00:16:45
08.05.2020 17:41 # 12
samet206
It is not something that changes immediately, so the use of oil with an unidentified brand is not something that changes immediately. your manual vehicle galba you? I trust the master of God, of course, it is not something that everybody can do. It is really necessary to pay attention to the issue of transmission. I think it hasn't changed. I have to look at it. Thank you.
samet206 2013-06-14 00:44:50
08.05.2020 17:41 # 13
emre_akdag
I would be glad if you share the results with us, my brother Samet :)
08.05.2020 17:41 # 14
okan77
similar problems exist in my vehicle. I will go for change at the first opportunity ... Thanks a lot for sharing
08.05.2020 17:41 # 15
Bugra
I came to my mind when I read the messages. though it is included in the manual, but how often should manual transmission oil be changed? Do we have friends with knowledge?
08.05.2020 17:41 # 16
samet206
[QUOTE = eksper_emre16] I would appreciate if you share the results with us, Samet brother:) [/ QUOTE]
Of course, I am going to share this with my friends.
08.05.2020 17:41 # 17
samet206
Friends, I went to the master, I changed the gearbox oil, I bought my oil, I paid 50 TL, I shifted my gears, I was satisfied, but I was glad that the stutters started again, we went back, looked at it, then the pressure was in the pad, I already knew that it would be like, He said that he would have a little impact on the transitions, even if he did not, but he said he would wear it originally. Smile As a result, if you trust your gearbox and thrust pad, I would definitely change your oil with certainty. Smile
08.05.2020 17:41 # 18
samet206
[QUOTE = onurazgin] I'm glad it works, but was it a problem because the pressure lining oil changed? i didn't understand it .. [/ QUOTE]
No no, it has nothing to do with it. After changing the oil, I went home with great pleasure, I thought it was flat, but after 3 days, the hangers started again, even if it was not as old as the old one, the master had already said, the pressure was changed to the pad, I said that I did not change it soon. we have already had a decrease in my oil, the good has come, relieved the gears but when I go again, I did a little test, the pressure was making the pad, so the oil change was not a solution for me. Unfortunately, I need to change the linings inside.
08.05.2020 17:41 # 19
sezar206
I also changed the oil, I did not have a problem.
