metal rubbing sound in the morning when the engine is cold
08.05.2020 20:39 # 1
losangarass
friends, especially when I run the car in the mornings and cold, there is no problem, but when I press the gas, especially after 1500 cycles, a great metal rubbing boot sizzling sound comes from the rifle and the right wheel comes from the belt, the sound comes from both, but it does not pass any more, but it does not happen again. We showed it to the master, he looked at the strap, there was no problem, he said no problem when he was warm losangarass 2017-11-30 23:23:44
08.05.2020 20:39 # 2
Bayram96
The same problem exists in me as soon as I get more from the clutch vehicle 106 1.4
08.05.2020 20:39 # 3
enesergin.34
Brother may also have a problem due to engine oil.
08.05.2020 20:39 # 4
Selcuk55
The timing belt balls of your vehicle should be checked and the crank pulley should also be checked and you can press the master while it is cold, or you can play the video in the morning by opening the bonnet.
08.05.2020 20:39 # 5
27BEN80
IF THE VEHICLE LPG LIMIT IS YES, I HAVE BEEN IN MY BACK THE ROOM IS MAKING THE SAME SOUND I think NORMAL
