Meaning and repair of ABS FAULT code
08.05.2020 14:10 # 1
Embarrassed
dear friends,
ABS FAULT
2004 307 launched ABS as soon as it hit the fire a while ago. Then the abs fault lamp; One burned, one went out.
I went to the service, they said we will disassemble and look; After they had been dismantled, the lamp never went out and now they say that the abs sensor and the axle ball will change.
Could there be another reason for the malfunction? Are these changes 350 TL?
I hope your answers will help other friends who come here, thanks in advance.
With respect from the mindless who passed from Çıtroen to Pejo.
08.05.2020 14:10 # 2
selcuk-307
welcome to us but it would be better if you introduce yourself first. and it is `` PEUGEOT '', not pejo. using PEUGEOT is also a privilege, not a fool ...
selcuk-307 2010-02-08 01:16:21
08.05.2020 14:10 # 3
selcuk-307
I had that problem, too. it was burning very rarely. It turned back to normal when I turned the engine off and on. I asked the master, he said the abs brain would have taken water. nothing has been repaired. I don't think they will be from the axle balls, whether they burned them completely when they look at the brain. If you said `` abs sensor '' I couldn't understand what it was. hope it will be well soon.
08.05.2020 14:10 # 4
fuat 92
08.05.2020 14:10 # 5
fuat 92
friends today is the same as friday i was going to go there was nothing i was going to run this light started blinking was it raining is it? i wonder please help
08.05.2020 14:10 # 6
phaselispa
It is a privilege to switch from citroen to peugeot. I have never seen a citreon brand, but citreonde has a lot of peugeot emblem products. PSA name is on its base ....
08.05.2020 14:10 # 7
higungor
The same problem happened with me, plugged into the computer, left rear wheel sensor pointless signal error appeared. The sensor got into the dirt there, removed and cleaned the problem solved they did not even receive money
08.05.2020 14:10 # 8
metin
sometimes the abs light and the stop lamp are on at the first start.
08.05.2020 14:10 # 9
sercinho
[QUOTE = text]
your problem is that my brother from acu can not give the necessary current in the first operation of the battery, i would have measured it in the service, low output in the service, it will be an accident because it will burn in the first time, it will burn after 3-4 seconds after the operation is not necessary,
08.05.2020 14:10 # 10
metin
[QUOTE = sercinho] [QUOTE = text]
I hope so. I am convinced that it is from the current, but they said they are missing the crankshaft pulley. I'll have the battery measured.
it makes sense what you already said. I tested it while the vehicle waited for a long time or while I was waiting.
08.05.2020 14:10 # 11
fuat 92
Is there any problem in using it, if I go somewhere like that? Or should I show it for sure
08.05.2020 14:10 # 12
BAHTIYAR
If abs work is not working, abs will not work, according to the new rules, the vehicle is considered to be defective in the inspection, hope it will be past.
