Masters, You Have the Solution, Help Me
27.12.2023 03:38 # 1
35turka
I have a 2004 Peugeot 206 1.4 8v Gasoline Automatic car. It has 153,000 km on it. Although there are no leaks, the necessary procedures have been done on the top cover to prevent future problems. The transmission fluid was changed once and driven for 1,000 km. After 1,000 km, the solenoid valves were changed again. The oil and related maintenance were done 5,000 km ago. My problem is this, masters, they have eaten up the 206. I used the 206 to go to work in the evening with no problems. The weather was 12 degrees, I had to go home, I started it immediately, and went and came back to work immediately. In the morning when I was going to return home I turned the ignition, the car started but the speedometer, tachometer, temperature gauge did not work, none of them moved. The engine fan is turning on. A line appears on the automatic gauge and stays that way. The airbag light is on. The engine malfunction light is on. The parking brake light is on. Then I go to my house 1 km away at an estimated speed of 10 km / h and park it. I want to start it again but this time it does not work. It starts very well, I hear the sound of the fuel pump, I tried to move the crankshaft forward to make it move slightly but it did not work. Is there anyone who has experience with this issue or who knows how to do this from experts, please help urgently. Thank you for your interest, best regards. 35turka2023-12-27 03:47:49
27.12.2023 03:42 # 2
35turka
The indicator is as follows: https://resimlink.com/QY-wgxKOFRkThe one in the photo is not running but stopped. I was trying to get home with an estimated speed of 10 km/h when I took the photo. 35turka2023-12-27 03:43:31
28.12.2023 20:57 # 3
35turka
I guess no one has met me now, I will call the master to come and take a look.
04.01.2024 11:03 # 4
35turka
I found the problem myself by trial and error. I disconnected the ABS connector and the car started. When it started, I took it to the repair shop. The repairman said that the ABS circuit was burnt out. Problem solved.
06.01.2024 00:19 # 5
ggitaristt
I'd say the car has gone into service mode, but I wouldn't have thought of pulling the ABS connector.
