massive voice from torsion
08.05.2020 16:52 # 1
BULUT06
slm friends vehicle 206 when the light passes by the back passenger into the muddy boar, hard sound is what it is not what do you think happened thanks for your attention ...
08.05.2020 16:52 # 2
escape82
yes bro it sounds the same from my car i hope you understand
08.05.2020 16:52 # 3
BULUT06
I searched for a little bit of torsion inside the area, it was said that the balls will be turned there and new balls will be installed. the total was said to be 450 lira in labor, the lathe will make the torsion again, I said laugh & nbsp;
08.05.2020 16:52 # 4
metin
Torsion balls may be scattered. The torsion will be disassembled, turned and new ball will be installed. & Nbsp;
08.05.2020 16:52 # 5
BULUT06
They said it was dead but when I asked another master tomorrow, when the lift was lifted on the lift, the shock absorber on the right did not move, forced it with a crowbar, maybe it was the shock absorber.
08.05.2020 16:52 # 6
ufuk91
Does the sound sound exactly "tonk tonk"? or sounds coming out of the pit to make it sound? then you are from us :)) there are many friends having the same problem in the forum, this torsion in the 206's is very big .. But I still did not go as soon as I started the vehicle, I turn on the tape, what sound I hear, whatever :)
08.05.2020 16:52 # 7
BULUT06
When this sound is entered into the pits, there is nothing on the flat road in the form of blunt signs. According to their heads, they want a price for the bushes.
08.05.2020 16:52 # 8
nurullah48
First of all my friend had the same problem, I would have done it and I shared it in the form before. I changed the rear torque kit to 150 TL, Turner 150 TL, 4 pieces of cartridges, 80 TL, 2 pieces of shock absorber, 180 TL, and workmanship. If the tornacers make the place to be torn while making the torsion, there is no problem. May Allah give you ease now ..
08.05.2020 16:52 # 9
zgr
[QUOTE = BULUT06] I have researched some of the torsion inner region, it was said that the balls will be turned there, and a new ball will be inserted. & Nbsp; the total was said to be 450 lira in labor, the lathe will make the torsion again, I said laugh & nbsp; [/ QUOTE]
said that in my service, the balls that will completely replace the rear torsions amount to 700TL. He said a little too much.
08.05.2020 16:52 # 10
BULUT06
206S NOT BALL BEARED DIGITALS PARTS WORKING LATCHES 250-300 ITS PREGNANT MANY, I WILL GO TO MAKE A DIFFERENT PROBLEM ..
08.05.2020 16:52 # 11
metin peugeot
all of the torsioned peugeots & nbsp; torsion has a problem & nbsp; it is found in our ways & nbsp; average cost & nbsp; 350 is 400%
text peugeot special serrvıs & nbsp;
08.05.2020 16:52 # 12
BULUT06
PIECE 50 LIRA WORKING 300-400LIRA THAT HOW IT DOESN'T WORK MORE THAT THEY MAKE CLEAR WITH THAT NO TURNING MACHINE TECHNICIAN HOW TO MAKE THAT YOU WANT TO MAKE THAT YOU WANT TO MAKE THAT YOU ARE ALWAYS LIKE THAT YOU WANT TO MAKE THAT YOU ARE ALWAYS LIKE THAT ...
08.05.2020 16:52 # 13
taskin
The sound had existed for 1 year, we did not care much, then the torsion ball was disassembled when dispersed 300tl bushes + we gave it to the turning operations + ball set right left + shock absorber + disassembly and installation process, we gave 650 TL in total 4 hours now I feel the sound of the shock absorber while passing through the muscles.
08.05.2020 16:52 # 14
bjkamil
I also sounded like a coin from behind. rear shock absorber changed. he also turned the ends of the iron rods connecting the two rear wheels together. there is no sound now. lonely the shock absorber got a little stiff back to me in the bumps "Big
08.05.2020 16:52 # 15
BULUT06
This incident is in cars with tors, I couldn't get it done.
