MASSING IN GEAR TRANSITIONS
08.05.2020 18:50 # 1
78peugeot78
friends 206 1.4 hdi manual gear car, there is a mass of noise when shifting the gears, when I pull my feet out of the gas while still in normal driving, engine ears, bottom linking wedge left and right axle completely changed but still I am still having problems in the city where I am living, someone who has experienced my problem before or in the service can someone help please: (((
08.05.2020 18:50 # 2
samet206
The original process of the axle has changed, the process of spare parts has changed, you have already written the solutions of the problem. Apart from this, a technical problem may not come to mind.
08.05.2020 18:50 # 3
ibanez_022
If it happens at which speeds at which gears, for example when driving at 4th or 5th gear at a speed of 90-100 km, this is not the engine's ears. Since the engine cannot adjust the fuel and oxygen level, it may suddenly fall into the body.
08.05.2020 18:50 # 4
menajer
The same kind of distress had been on me. The 3 screws holding the ears of the luck were loosened and even it was going to fall off. I was thankful. This is the result when some masters do not check the apprentices and leave them to the apprentices. Manager 2014-10-21 09:04:09
08.05.2020 18:50 # 5
78peugeot78
friends, maybe there are friends who have the same problem, first of all, after doing what I wrote above, if it is still mass, if the problem is the change of the cross gear set yesterday, we opened the axle yesterday, I put the axles right and left, and the part of the gap is obvious, we will share with you tomorrow.
08.05.2020 18:50 # 6
78peugeot78
thank you friends I changed the printing pad to your messages, it was the first change since 2006 ... when my other friend was doing in every gear, when I took my foot off the gas during the gear shifts while taking off .. 78peugeot78 2014-10-22 16:10:31
