Markings on the Dashboard
08.05.2020 17:09 # 1
uyarrr
Friends just bought & nbsp; 2003 model & nbsp; 307 1.4 hdi xr & nbsp; & nbsp; Model & nbsp; contact & nbsp; shortly first, & nbsp; Mark in 1 image & nbsp; & nbsp; followed by & nbsp; Mark in the 2nd image & nbsp; & nbsp; Turns out & nbsp; & nbsp; 5 seconds & nbsp; after the two pass by & nbsp; Coming to km time. & nbsp; each & nbsp; when I turn the ignition on a & nbsp; next time these marks & nbsp; is flashing.
What are these, what are the meanings of friends?
& nbsp;
& nbsp;
PICTURE & nbsp; 1
& nbsp;
& nbsp;
PICTURE & nbsp; 2
& nbsp;
08.05.2020 17:09 # 2
hsnsnl
First friend of the vehicle, the remaining km of the vehicle is
and the second one shows the oil level of the vehicle, but when you start this vehicle for the first time, it shows the correct values, it can mislead you. the best thing to do ..
08.05.2020 17:09 # 3
106fb
The first picture shows the maintenance time of your vehicle. The second picture shows the amount of oil in the dipstick.
08.05.2020 17:09 # 4
uyarrr
so this & nbsp; Is it normal to have the marks appear, especially the oil marks? & nbsp; in fact the & nbsp; Oil change was made 1 month ago, approximately 1000 km after the change.
08.05.2020 17:09 # 5
okan4037
In one question, I had the LPG on my 2002 model automatic gear, but no lamp was lit .. Does anyone know what this LPG is? & nbsp;
08.05.2020 17:09 # 6
Serkan
[QUOTE = alert] so this & nbsp; Is it normal to have the marks appear, especially the oil marks? & nbsp; in fact the & nbsp; Oil change was made 1 month ago, approximately 1000 km after the change.
& nbsp; & nbsp; & nbsp; Dude the oil indicator appears whenever the ignition is turned on, if your oil level is full, 6 frames will appear as in the picture, the squares will go out one by one as the oil decreases, if it decreases enough to damage the engine, 6 flat chips (-) and min. will appear and the display will flash continuously.
& nbsp; & nbsp; & nbsp; If enough oil is added to damage the engine, 6 frames and max. text is blinking, it is the most ideal level of oil compared to the screen, but still not trusting the screen, it is always more reliable to check the oil from the dipstick.
& nbsp; & nbsp; A lot of vehicle maintenance km, the vehicle sets it to 20.000 km, you should take care of it at 10,000 km.
Serco05 2012-11-20 13:58: 05
08.05.2020 17:09 # 7
uyarrr
[QUOTE = Serco05] [QUOTE = alert] so this & nbsp; Is it normal to have the marks appear, especially the oil marks? & nbsp; in fact the & nbsp; Oil change was made 1 month ago, approximately 1000 km after the change.
& nbsp; & nbsp; & nbsp; If enough oil is added to damage the engine, 6 frames and max. text is blinking, it is the most ideal level of oil compared to the screen, but it is still not trusting the screen and it is always more reliable to check the oil from the dipstick.
& nbsp; & nbsp; A lot of vehicle maintenance km, the vehicle adjusts it to 20.000 km, take care to have your maintenance done at 10,000 km.
& nbsp;
& nbsp;
thank you so much bro
08.05.2020 17:09 # 8
mmuussaa
Friends my car 2001 pug206 xr gaseous I opened the ignition in my car, the direct maintenance km is coming out, the oil shows are not coming. I wonder if there is such a feature in my vehicle. Do you have a peer tool oil indicator on everyone?
08.05.2020 17:09 # 9
halilefe
My dear elders, I have 2 06 1.4 HDI XT 2004 & nbsp; I just bought information thanks to the posts shared in the forum, and I found out what the same signs came to me. But I have a problem like this, my cycle time is in the 60s with defective travels. It does not fall to 0 at all.
