Manual Fan Button
Homepage » PEUGEOT MODIFIED PLATFORM » How To
19.01.2021 19:21 # 1
QqnLc4N
I would like to make a pop-up fan button that I can control from the inside of my Peugeot 206 1.6 XT 2001 model vehicle. Example: When I press the FAN 1 button, the fan rotates at the 1st stage speed. When I press the FAN 2 button, the fan rotates at the speed of the 2nd stage. However, if the heat rises, the installation that I manually open and the installation that enables the vehicle itself to operate when necessary should not interfere with each other and cause me problems. Do not let the fan originally opened by the vehicle short circuit with mine.
Can you help me?
20.01.2021 21:11 # 2
littlenikksay
Useful application, follow up ..
23.01.2021 17:14 # 3
QqnLc4N
up+++
29.01.2021 20:06 # 4
QqnLc4N
+upp
03.02.2021 09:12 # 5
I do not explicitly recommend that such operations are done, but. why do you need something like this.
03.02.2021 13:05 # 6
QqnLc4N
[QUOTE = sonerkyl] I clearly do not recommend doing this type of operations, but. why do you need such a thing. [/ QUOTE]
I think of the fan circuit, which will not be noticed on a long road, as an emergency system.
06.02.2021 20:58 # 7
QqnLc4N
[QUOTE = sonerkyl] I clearly do not recommend doing this type of operations, but. why do you need something like this. [/ QUOTE]
How is it made? Can every electrician do it .. I wonder if there are issues to be considered while doing ..
