Manual 208 transmission problem (master wanted)
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
02.06.2021 21:38 # 1
birGarip
Hi guys.
Ramadan, I bought a car as a motorcycle fan.
208 2013 1.4 Active manual at 210k km. I bought my father's car. My wife will also use it.
There is a problem with my vehicle. Gear...
1. And it has a hard time shifting into 3rd gear. Even 1st gear is difficult to engage, it does not fit properly. When using it, when you put it from 2nd to 1st, it doesn't go through completely, and when it's half past, it makes a squeaky sound, then I fully depress the clutch and switch gear again. Sometimes I stop and linger for 2 3 seconds, I honk on the road. I'm afraid to stop at a red light..
Is there any master you would recommend for a solution? I'm from Kocaeli.. Istanbul vs. it doesn't matter, I'll make an appointment with the master on the phone and go.. As long as you have a competent person, you can solve my problem.. We are new in Izmit. Our environment no
I need your suggestions..
Greetings
12.11.2021 23:28 # 2
Puger208
There is a professional automaker Atilla in Izmit. He says he is competent in his job, if I can do it, I can do it, if I can't, I can't. I say go.
14.11.2021 17:12 # 3
GokhaN
Looks like it's time to change the clutch pad.
