Malfunctions
08.05.2020 18:26 # 1
gebedek
Hello friends. I would like to share with you the problem I could not solve for 5 months.
The problem with the vehicle is that when it is cold, the car starts at the first start, but stops after two seconds. I have the same problem with the vehicle lpg and lpg. After the 5th run, it works with shaking excessively. Even if I root the gas, the tachometer does not go up, the vehicle does not go.
I am waiting for your comments and suggestions.
Unfortunately, Ardahan and all the masters in Karsa exceed us.
08.05.2020 18:26 # 2
Alicilik
There are reasons pushing it towards the flow meter.
08.05.2020 18:26 # 3
gebedek
P0172 System too rich (bank 1)
P0108 Manifolt Absolute Pressure / Barometric Pressure Circuit High Input
P0113 Intake air temperature sensor circuit, short to positive or open circuit
P0501 Vehicle speed sensor step / efficiency
P0171 System Poor (bank 1)
08.05.2020 18:26 # 4
gebedek
What is your suggestion about the solution?
Also, the car burns very badly and the traction is very low
08.05.2020 18:26 # 5
semus
buddy had a similar fault in our friend. it wasn't exactly the same, but it did not leave any unchanged parts in the engine. Ask the last insurance. I mean, before you change the parts, I say you look at the fuses.
08.05.2020 18:26 # 6
gebedek
Thank you for your attention. If you get more detailed information, can you write
08.05.2020 18:26 # 7
elsoberano
There is a caravelle that we use in the workplace. When we first started it, there was a low performance for not eating gas, not exceeding certain cycles. as if you are a flow meter.
08.05.2020 18:26 # 8
oguzhan29
can be from the air flow meter.
08.05.2020 18:26 # 9
gebedek
A master, they bought the electricity from here. He said that it may be because the current is low. Could something like this happen?
Would you suggest to replace or clean rather than the air flow meter
08.05.2020 18:26 # 10
semus
it is better to change it, you cannot get definite results
