Malfunction light |
| 08.05.2020 20:25 | # 1 |
![]() Hello friends. The car pejo 307 has begun to flash a malfunction light today from the bottom to the second right, with what looks like a wavy light on the side of the indicators. What does this mean, can you help? thanks
| 08.05.2020 20:25 | # 2 |
Oktkor |
Change where you get fuel, sir. There was moisture in the diesel filter. Your sign is a little different. |
| 08.05.2020 20:25 | # 3 |
[QUOTE = Oktkor] Change where you refueled, hodja. There was moisture in the diesel filter. Your sign is a little different. [/ QUOTE] my teacher is asking the first lamp from the bottom, the second lamp, you ask him, let me tell him my car engine coolant means antifreeze min has come below the limit, so as a supplementary note, my bnm has come to my car 3 times, when the light goes down, this lamp is on, the sensor lights up around 110tl. I got tired, I took off the last socket. I immediately put antifreeze on it. You see it on the head.
| 08.05.2020 20:25 | # 4 |
Firstly, get well soon. the same problem happened to me 3 weeks ago. my vehicle was 206 hdi. When I first started the car in the morning, it gave the same beacon and stop warning. The coolant of the vehicle was diminished or even left. when I added the water, it flowed through the barriers. I showed it to the master, the thermostat is missing from the seals that have completed its life. Even the seat where the gaskets fit was broken. The thermostat changed completely, I bought the one with the request. He said the original took 300 TL + 70 TL. actually the original price of the piece is max. 200 TL but I had to buy it from the mechanic's part because it was dismantling everywhere. He claimed that the piece bought for 150 TL was not original. He said that if he does, he will not accept any liability.
| 28.11.2021 22:15 | # 5 |
Hello, that lamp warns that there is water or moisture in the diesel oil, it's like a disease in the pejos, if you're around the Anatolian side of Istanbul, contact me, I'm an auto mechanic, come to my service and we'll take care of the problem, have a nice day :)
