Malfunction lamps are on |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208 | |
| 08.05.2020 21:18 | # 1 |
| 08.05.2020 21:18 | # 2 |
is it going out later
| 08.05.2020 21:18 | # 3 |
sonerkyl |
First of all, welcome to us. If it flashes after 3-5 seconds when you turn the first contact, there is no problem, hodja. If there is a warning sign when starting the vehicle, then there is a problem.
| 08.05.2020 21:18 | # 4 |
Hello sir, The same problem happened to me 5 months ago. When I connected the vehicle to the machine and went down to the details of the fault codes, we saw that it was sourced from the accelerator pedal. I deleted the fault codes and it never happened to me again. Do not be afraid that all malfunctions will be burned at the same time. They all trigger each other.
