malfunction lamp
08.05.2020 14:57 # 1
lion17
Hi friends, I have a 2004 model 1.6 Qiksilver, I had a zavoli tube, but I constantly put the malfunction lamp on it and put it back several times. We couldn't solve the problem.
08.05.2020 14:57 # 2
Haksen016
There are friends who are quite knowledgeable about this in the forum, you can also follow some very descriptive comments on this topic with your friend, who has a nickname in cecoli.
08.05.2020 14:57 # 3
ceronimo1978
strong probability rich / poor fuel event teacher. I can recommend you to change the settings where the lpg is installed. I had the same problem.
08.05.2020 14:57 # 4
nteker
Sir, this problem is normal in the cars with peugeot lpg, there is no burning. This lamp is on because the vehicle perceives the LPG like any other fuel, but it has no harm, I suggest you get used to this light, because no matter how much you put it out, it will come on again after a while.
08.05.2020 14:57 # 5
ceronımo my brother has already explained the incident. If you want to see the description of this breakdown light, you have to connect and look at the peugeotplanet. we can only say so briefly. If the malfunction light never burns on gas, but when it gets to lpg, it lights up continuously or intermittently, it is very clear that the "mix error" buda settings are wrong ...
08.05.2020 14:57 # 6
ceronimo1978
cecoli is definitely the first thing to do. I read your writings always approach with the right determination. Congratulations. Yes, the mix error is absolutely.
08.05.2020 14:57 # 7
thank you brother bro :)) share my purpose ... happy if i can benefit you with my work ...
08.05.2020 14:57 # 8
Onur
Thanks to cecolinin, I started to look lpg warm Gülme I'm not doing a lot of miles this time but I'm thinking of appreciation towards spring
08.05.2020 14:57 # 9
selfat8
This day, the malfunction lamp did not light up since the lpg was installed.
08.05.2020 14:57 # 10
ceronimo1978
Touring with gas at this time is not mind-blowing friends. Easy to calculate 70 TL 300 km in Istanbul city. Performance is number 10. I recommend it to everyone. Be prepared for 2 possible troubles in the 307s. Decorate solution.1 The engine fault light comes on strictly set. 2 Petrol needle warning light comes on (No need to stress, 10 ll fuel pointer will continue on its way to the old place.
Respects.
08.05.2020 14:57 # 11
deme
my malfunction lamp is on both petrol and lpg. rather, it burns right after the vehicle starts
