Making Open Air Filter Pipe.
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 16:10 # 1
metin
Hello friends.
& nbsp;
I bought a green air filter from our "mimit" brother from our weekend forum. I put it on my vehicle, but I don't think it's very solid. A good piping system is required. Because I can say that it did not happen exactly with the pipes in my hand. (He's standing in a safe way now) Also, it is not good because it is spiral, because the pipe through which the air will pass must be as smooth as possible.
& nbsp;
I want to install the pin filter and air filter as I want, which we know as the most beautiful and cheapest.
& nbsp;
I kindly ask you, my dear friends, to share their knowledge and advice on this subject. If you have a better idea, I will work in that direction.
& nbsp;
Thank you.
08.05.2020 16:10 # 2
I Love My Pug
First of all, good luck with your new filter :) is the pin pipe plastic? or steel? Have I looked on the internet always looking plastic? I Love My Pug 2011-09-28 16:07:13
08.05.2020 16:10 # 3
metin
[QUOTE = I Love My Pug] First of all, your new filter :) I want to ask is the pin pipe plastic? Is it steel? I always looked at the internet, it looks like plastic?
Did you mean my aspirator pipe as steel?
& nbsp;
yes, I am also searching online. it looks the most durable and malleable plastic.
08.05.2020 16:10 # 4
If you want a question, a text order, maybe you have extra pipes left, or you can buy and install the original filter pipe from murat brother ???
08.05.2020 16:10 # 5
brutal
Hodja, that work will happen with a pin but why .. You will say why because it can melt, it can transmit the temperature to the air .. But if you ask for the material wrapped from the insulation material to the heater pipes, it becomes a monster and pimaş makes a different sound .. :)
08.05.2020 16:10 # 6
sedataksu
Friends pin melts and breaks due to heating and cooling. I would rather have my own tool for elastic rubber-wound rope, which I used for other works. Can you write the diameter of the mouth?
08.05.2020 16:10 # 7
metin
[QUOTE = HeRo1727] If you want a question for a text order evening dress, maybe you have extra pipes left, or you can buy and install the original filter pipe from murat brother ??? [/ QUOTE]
& nbsp;
yes it makes sense. any peugeot has a long filter pipe. first of all I need to measure the diameter.
08.05.2020 16:10 # 8
metin
[QUOTE = brutal] Hodja, that work will happen with the pin, but it will not. Why will you say, because it can melt, it can transmit the temperature to the air. DIV> & nbsp;
What material is
? this is the first time I hear.
08.05.2020 16:10 # 9
metin
[QUOTE = sedataksu] Friends melt the pipe and it breaks because of heating and cooling. Instead I have a very nice break, I would make my own vehicle. Let me ask you if you can write the size of the air filter mouth in the first place. >
08.05.2020 16:10 # 10
Maybe it works for you:
Dimensions for the following filter kit:
Base Outside Diameter: 5.197 in (132 mm)
Flange Inside Diameter: 2.52 in (64 mm)
Flange Length: 0.748 in (19 mm)
Height: 4.567 in (116 mm)
Top Outside Diameter: 3.504 in (89 mm)
koliva 2011-09-28 16:39:34
08.05.2020 16:10 # 11
After 3 days, you will insert it, it burns so why are you wearing it dude:) & nbsp;
08.05.2020 16:10 # 12
[QUOTE = EmRaH] After 3 days you will sting, why is it burning, why are you wearing it dude:) & nbsp; [/ QUOTE]
& nbsp;
In my opinion. .. If he uses the master without making a sound, he will not put it in satire. I used it so much that it didn't make any difference. It looks like you still understand this heat logic "Blink"
& nbsp;
If you give gas to the place where I will hear the sound, or if you have a revolving where it is unnecessary, it will burn again in the same way, even if it is in the original filter, not the filter ... This is a test tested and approved by me.
& nbsp;
Open filter does not increase fuel. If the user presses the extra throttle to hear the sound, the fuel will naturally increase ...
& nbsp;
I think that the text will be able to go like my brother and make no sound "Grin"
08.05.2020 16:10 # 13
brutal
[QUOTE = text] [QUOTE = brutal] Professor, that work will happen with the pin, but it will not. Why would you say because melting can transmit the temperature to the air .. But if you ask for the material wrapped from the insulation material to the heating pipes, it will make a monster and make a different sound. :) [/ QUOTE] What material is
& nbsp;
? I hear it for the first time.
08.05.2020 16:10 # 14
sedataksu
[QUOTE = sedataksu] Friends melt the pipe and it breaks because of heating and cooling. Instead I have a very nice break, I would make my own vehicle. Let me ask if you can write the diameter of the air filter in the first place. [/ QUOTE]
Friends hydraulic hose & nbsp; There are different types from the site I have given. You can use the air hose as well. You can have it in the hardware stores located in the shipyards street in Karaköy. You can cut it to the extent you want. in hoses.
08.05.2020 16:10 # 15
metin
& nbsp;
cem brother has given the necessary answer "Language
08.05.2020 16:10 # 16
[QUOTE = CeCoLi] [QUOTE = EmRaH] You will sting after 3 days. Why do you wear it, dude:) & nbsp; [/ QUOTE]
& nbsp;
I don't think it will sting. .. If he uses the master without making a sound, he will not put it in satire. I used it so much that it didn't make any difference. It looks like you still understand this heat logic "Blink"
& nbsp;
If you give gas to the ground where I will hear the sound, or if you have a revolving where it is unnecessary, it will burn again in the same way, even if it is in the original filter, not the filter.
& nbsp;
Open filter does not increase fuel. If the user presses the extra gas I will hear, the fuel will naturally increase ...
& nbsp;
I think that the text will be able to go like me, without making a sound "Grin"
There is a difference between Cem Bey Lpg + Manual gear + automatic gearbox vehicle normally it doesn't get under 30 cents anyway .. I know that the fuel will increase as I press to hear the sound, but automagnic is getting worse for me.
08.05.2020 16:10 # 17
mimitt
The pipe to be used should not soften in the face of the heat, when it becomes soft, when the motor starts to suck, it may shrink and prevent the entrance of air in the pipe.
will also burn the filter for a while after installing the filter, there is no doubt about it, but after a while it will stop gassing and return the normal calm to daily use, the difference in fuel will turn positive.
If the
filter or something other than the filter is left open, be careful, the text, the dirt that will go to the blog, and the light dust particles may be harmful.
mimitt 2011 -09-28 16:59:05
08.05.2020 16:10 # 18
metin
[QUOTE = brutal] [QUOTE = text] [QUOTE = brutal] Hodja, that work will happen with a pin but why .. You will say because melting can transmit the temperature to the air separately. What does it take ..:) [/ QUOTE] What kind of material is
& nbsp;
? I hear it for the first time. QUOTE]
& nbsp;
this is what you are talking about? .com / Files / NewsImages / 1400 / 176x97 / 12cb6044-c3a9-4bec-82b1-9d746c9c1b5b.jpg "height =" 97 "width =" 176 "border =" 0 "/>
& nbsp; < / DIV>
I also ask you to try not to use capital letters as per the forum rules (:
08.05.2020 16:10 # 19
[QUOTE = mimitt] the pipe to be used should not soften in the face of the heat, when the motor starts to absorb when it softens, it may prevent shrinkage and prevent air intake.
will also burn the filter for a while after inserting the filter, there is no doubt about it, but after a while it will stop gassing and return to normal daily use, the difference in fuel will turn into a positive direction. [/ QUOTE]
This over burning is entirely due to your filter's desire to hear the sound "Grin"
08.05.2020 16:10 # 20
metin
[QUOTE = mimitt] the pipe to be used should not soften in the face of the heat, when the motor starts to absorb when it softens, it may prevent shrinkage and prevent air intake. It happens.
will also burn the filter for a while after installing the filter, there is no doubt, but after a while it will stop gassing and return to normal daily use, the difference in fuel will turn into a positive direction.
If there is an open place other than the filter, be careful, the text, the dirt that will go to the blog, and the light dust particles may be harmful.
& nbsp;
It is certain that fuel will increase a little in the first time, but I hope we will catch up on the long road.
& nbsp;
has no place to breathe air from the filter, but I couldn't get an "S" on the incoming pipe, the battery was pressed a little. I want to draw a clean installation again. If I find the material I will use, I will do what I do right away, but every material has + and -.
& nbsp;
but of course I would like to kiss a filter pipe for 100 TL under an open air filter from the eyes of the seller.
Page : / 4
