Making Information Display Led
08.05.2020 15:48 # 1
tigerland
Friends, the information screen was extinguishing, I opened it to do it, one of the light feet was not touching and I fixed it. I couldn't take much pictures but ..
I glued the led strip into the Slot. I passed the soldered cable through the bulb socket and canceled the bulbs, soldered the metal feet and the result ..
Uploaded with ImageShack.us
Erb's 2011-07-11 20:44:50
08.05.2020 15:48 # 2
dinoco
but very stylish bravo Thumbs Up
08.05.2020 15:48 # 3
tigerland
thanks .. gotta do the indicators :)
08.05.2020 15:48 # 4
It was very nice. Congratulations.
08.05.2020 15:48 # 5
ose
> Good health.
08.05.2020 15:48 # 6
dinoco
Do it in me, you should do it all. Let them all be the wife .. but then publish the pictures .. let me tell you what color the bidet is wearing and what kind of light bulb it is.
08.05.2020 15:48 # 7
tigerland
Strip with 6 leds. There are electricians with scissors you cut from anywhere you want. there is a tape on the back to stick
08.05.2020 15:48 # 8
is nice but does not break out electrically: S
08.05.2020 15:48 # 9
Erbın, I think this is yours, you are talking about SMD 3528 series. It can be cut in 3 leds. There are also SMD 5050 large led ones. It brightens the tab more. You have a double-sided stiffener behind it and you stick it. If it gives direct 12V, it works without any problem. Some can be worn outside. The top is covered with transparent silicon. It is not affected by water ...
As far as I know, they are sold in rolls. I think they're all 5m.
08.05.2020 15:48 # 10
good health to your labor
08.05.2020 15:48 # 11
tigerland
[QUOTE = CeCoLi] Erbın I think you said this is talking about the SMD 3528 series. It can be cut in 3 leds. There are also SMD 5050 large led ones. It brightens the tab more. You have a double-sided stiffener behind it and you stick it. If it gives direct 12V, it works without any problem. Some can be worn outside. The top is covered with transparent silicon. It is not affected by water ...
I guess I bought 1 m 10 TL at the master. You can get it from interior electronics as interior lighting. I made luggage and torpedo led. When you do it with solder, it will not be a problem, but if you do it with just hitting it, it can make chassis. With 12V led strip, you can illuminate any place with a beautiful soldering. Ashtray, luggage, glove box, ceiling lamp etc.
08.05.2020 15:48 # 12
tigerland
In addition, if you want to change colors, instead of the orange transparent nylon on the back of the LCD screen, you can get the color nylon piece you want from the stationery and make it in blue yellow red white. The orange template inside the led white is already orange. I did not change it so that harmony does not deteriorate :)
08.05.2020 15:48 # 13
Congratulations, Erbin looks very stylish :)
